Gregory Brissitt Posted April 17, 2015 Report Posted April 17, 2015 hey , ???? i have 2 rocford fosgate prime 1200 D amps.that i wish to connect to my 2 soundqubed HDS312 2ohm sub.whats the best way to connect them , would u connect both amps together and let them play the subs from one terminal ,, or you connect one sub to one amp individually ,,,, could i get a diagram or the info on how to make the connections thanks,
dbmode2 Posted April 17, 2015 Report Posted April 17, 2015 I use this site all the time and this site will give you some numbers as will make sure you have a multimeter to check http://www.jlaudio.com/header/Support/Tutorials/Wiring+Dual+Voice+Coil+%28DVC%29+Subwoofer+Drivers/Tutorial%3A+Wiring+Dual+Voice+Coil+%28DVC%29+Subwoofer+Drivers/287544
dbmode2 Posted April 17, 2015 Report Posted April 17, 2015 hey , ???? i have 2 rocford fosgate prime 1200 D amps.that i wish to connect to my 2 soundqubed HDS312 2ohm sub.whats the best way to connect them , would u connect both amps together and let them play the subs from one terminal ,, or you connect one sub to one amp individually ,,,, could i get a diagram or the info on how to make the connections thanks, since this amps are non stripable you will have to run rca cable to one and link it to output and run another rca to the input to the headunit just wire 1 sub to the amp and the other one to the next amp
Gregory Brissitt Posted April 17, 2015 Author Report Posted April 17, 2015 ok thanks for that info i see some sites giving instruction , but i just want to make sure i get it the correct way and the most reliable and safe way so i welcome all the suggestions
BoomZoom808 Posted April 17, 2015 Report Posted April 17, 2015 I don't think you can strap those amps so 1 to each sub with each sub wired in parallel for a 1 ohm final impedance on each amp. 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
reedal Posted April 17, 2015 Report Posted April 17, 2015 and dont forget to gain match so theres equal output to each sub.... SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
