how would this sound?
I'm having a tough time trying to figure out you box specs. Could you give us a picture?
What specific 10" subs are you going to use? A 3" port isn't really big enough for anything these days.
Builds:
It is a pioneer shallow mount sub. Ts-sw2502s4. The box I'm thinking on building inside is like 36 in. Deep 12 in. W and H. with two enclosed at 8x12x12 for the shallow subs. And 1 area 16x12x12. And I'm sure I need a port in the 16x12x12 area.sorry it is a I thought at the moment.
I assume when you say "4th order", you mean a 4th order band pass box. Ported boxes are 4th order designs as well.
What do you hope to accomplish with a band pass box? If you have space for a band pass box, why are you using shallow mount subs?
Builds:
I'm sorry guys I ment a 4th order not a t-line.
Finally your OP makes sense, you are wanting a 3 chamber 4th BP 0.75 net for the sealed chambers 1.5 net for the ported one. The one thing that looks really bad is the single 3" port.
well I got 2 for a really good deal off someone in a fatory sealed box so I want tool around with this box to see what this 4th order is like. And if I like it I will go to 2 good 12s down the road.
yes the subs are in a factor sealed box of .70 so to make it a easy 2 to 1 build .75 two times and one 1.5 sf. My OP is what I really am asking is about the port.
Your port area (a single 3") is very low for both of those subs if this is all you want to know.
  • Who's Online   0 Members, 0 Anonymous, 4706 Guests (See full list)
