CZ702 Headunit Issues (static)
I just got the Clarion cz702 installed and turned it on for the first time. As I was messing with the settings it was on a station that was all static so I didnt think anything of it. However, when I went to BT the static remained. You can hear it up till about 10 or so then the music drowns it out but below that its all I can hear. The RCA's are fine bc all I did was switch out HU's and they were fine before. Ill try and get a video up soon. Any ideas on what the static could be from? Also in the manual it says to click in the volume control to get to the menu but when I do nothing happens, I have to go through the DISP/ADJ button and get to it that way. Is that normal?
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
Mine has no static of any kind.
As for the menu you push the volume control to select what you want to adjust when you are in the menus.
Alright I was just curious about that part. I dont know why the static is there. I looked around and somewhere is said it could be the internal amp so I turned that off yet the static remained.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
Maybe you got a bad one, it does happen with any electronics.
That would be my luck haha. I tried setting the gains and I had clipping with the gain barely even touched and the HU was set at 30.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
Here's a little video
https://youtu.be/9wF95tFzj_o
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
Just tested the HU with the DD1 and its distorting at 32. Is that normal? I know a lot of you say it's clean throughout.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
I got it from crutchfield, I'll contact them and see if I can return it for a new one.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
  • Who's Online   0 Members, 0 Anonymous, 392 Guests (See full list)
