Few electrical questions
So i ended up getting a singer 270a alt, one blockshakers 55ah battery, and one kinetik hk2400 for my 2 amps. The 2 amps are ab vfl175.1 and alpine pdx5. I currently have one run of 0 gauge. When playing full tilt for a whole song my voltage drops to o12.8 to around 13.2. Is it true that until you drop below 12.8 volts your using your alt?
I am running around 4k rms. id like to keep voltage around 14 volts. The alt i have charges at 14.8 as i have bypassed the pcm because my cars pcm wont regulate it right. If i do another run of 0 gauge or swap it out for 2/0 gauge would that keep voltage higher by alot. Or would i be better externally regulating it to 15.3, so when the car warms up i still will sit around 14.7?
i wont buy another alt but wanted opinions as i see others running smaller alt with more power
Im going to be runing a SINGLE run of 2/0 OFC for a sundown SCV4000 or Nendo 5500 aslo a SAX100.4, and ive been told by many people this will be good, so i would think 4000 rms is okay on a single run of 1/0, that is if its OFC...
TEAM PRESSURED LOWS
2000 Dodge Durango
6 Sundown SA 15s
6th Order B-Pillar Wall
XS Power Batteries
Mechman Alternators
That is what held me back at first, and yes its true, but i'm only doing the run of 2/0 to the back batteries, then from there 1/0 to amps, so i dont have to worry about 60 dollar fuses, smart huh? ;)
TEAM PRESSURED LOWS
2000 Dodge Durango
6 Sundown SA 15s
XS Power Batteries
Mechman Alternators
You still need to buy 2 fuse holders.. $110 can go towards a spool of 50 feet of ofc. if you already have ofc you just have to buy 17 feet and you have left over money
You're going to spend nearly $200 to get that 2\0 property
sorry sir, but two fuses for what...? im doing a SINGLE run of 2/0 from front to back....
TEAM PRESSURED LOWS
2000 Dodge Durango
6 Sundown SA 15s
XS Power Batteries
Mechman Alternators
Burn that fucker to the ground.
No seriously, if its just a run from the front batt, to back, where does it all have to be fused?
TEAM PRESSURED LOWS
2000 Dodge Durango
6 Sundown SA 15s
XS Power Batteries
Mechman Alternators
U need to fuse the wire from front to back 12 in from battery. some people fuse in front and back for there power runs. I would do another run of 1/0 ofc but that is me I'm running over 5k soon to be 6k on 3 runs of 1/0 SHCA ofc . Did u do the big 4. Do u have good solid grounds?
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
thats what im saying, fuse up front, why would i need another before the back batterys
TEAM PRESSURED LOWS
2000 Dodge Durango
6 Sundown SA 15s
XS Power Batteries
Mechman Alternators
  • Who's Online   0 Members, 0 Anonymous, 3413 Guests (See full list)
