Joe X Posted April 28, 2015 Report Posted April 28, 2015 Same as above but from another pic hosting service, if this doesn't work then probably the issue is with your browser or something else on your side, could try accessing from somewhere else: Here is a suggestion for the box aimed for the lows, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 4 1/4", figure is just an assembly guide:
buff_n3rd Posted April 28, 2015 Author Report Posted April 28, 2015 Same as above but from another pic hosting service, if this doesn't work then probably the issue is with your browser or something else on your side, could try accessing from somewhere else: Here is a suggestion for the box aimed for the lows, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 4 1/4", figure is just an assembly guide: Thank you Joe.
buff_n3rd Posted April 28, 2015 Author Report Posted April 28, 2015 Would this be a decent amp to go with? More power? Less power? From my reading, these speakers can always use more power.http://www.sundownaudio.com/index.php/products/amplifiers/item/scv-2000d.html
ToNasty Posted April 28, 2015 Report Posted April 28, 2015 I'd use the 1500 ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
buff_n3rd Posted April 28, 2015 Author Report Posted April 28, 2015 I'd use the 1500 Thank you Orion.
