OldsBoomer Posted April 30, 2015 Report Posted April 30, 2015 Hey guys i just bought a 2000 S10 with 192k on it. This is my second S10 but this is the first 4wd. The guy i bought it from said he swapped a used rear into 6 months ago. Little did he know he put a ZR2 rear into it when the truck didnt come with that package. So now the rear has i believe 3.73 gears and the front has what i think is 3.43 gears. He said the howling noise(like having really nobby mud tires) just started after 6 months of driving. I took the rear driveshaft off to drive it home in 4hi and it mad an awful noise. I need to figure out what parts i need to swap out and change to what gearing so i can get this to work properly. I can do drive train work, im just not experienced with it and dont know how to diagnose these issues. Im much better with the motors. If you all could point me in a direction and give me some advice thatd be greatly appreciated. Suburban Coming Soon
Skullz Posted April 30, 2015 Report Posted April 30, 2015 Mismatched gearing on the front and rears will wear everything in both the front and rear differentials Could have worn gears, bearings, spider gears and who knows what else happened to them. Most likely going to need boneyard replacements. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
STEvil Posted April 30, 2015 Report Posted April 30, 2015 Bearing going out or vacuum line/switch on top of transfer case is bad. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
OldsBoomer Posted April 30, 2015 Author Report Posted April 30, 2015 new gears up front and probably a transfer case. should managae it. any reason you can think of that itd take so long to have an issue? Suburban Coming Soon
Skullz Posted May 1, 2015 Report Posted May 1, 2015 There was a lot of pressure put on the pinion bearings from the mismatched gears, so it is possibly the culprit but tough to say for certain. It also depends on how much it was driven over that period of time. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
OldsBoomer Posted May 1, 2015 Author Report Posted May 1, 2015 I'm unhooking the front drive shafts today to prevent further damage Suburban Coming Soon
andy. Posted May 1, 2015 Report Posted May 1, 2015 Mismatched gears only causes problems when the tcase is locked in. Pull the drive shafts and see if there is excessive slack in the pinion, either rotational or up and down.
STEvil Posted May 5, 2015 Report Posted May 5, 2015 doubt its the pinion, you should see the rear output on my transfer case lol, scarry amount of play. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
