Kicker comp 8 for midbass
micker
Fs of 40hz
Response of 30-500hz
Can't install in kicks as there are computers in there for the car
Doors are deadend and will also contain 6.5"comps
I can use amp and head unit crossovers
I can hi pass front rca on h/u at 80hz
And low pass the amp at 250hz (amp is 50-250)
Then set my comps at 250hz high pass
Or buy inline eq witch I think is better
And banpass 80-300hz 8"
And hi pass comps at 300hz
Looking to feed comp8" with 75rms
Amp is 75rms @4ohm 85rms @2ohm
I have 2 sets of kicker ds650.2 60rms rated
So I was either 1 set each door (4door) front on 75rms rear of h/u
Or put both in from door and run amp at 2ohm (85rms) each getting 43rms
Thanks in advance
If you have no place to put them, then why use them?
Midbass require a lot of power and 85w is a joke for the amount of power you really need, 200w and up from an amplifier so you can make adjustments for getting the correct amount of midbass.
As you increase in speaker sizes, you have to increase the power going to them.
You will most likely have to build pods for the midbasses, and whether you attach them to the door or in the kicks is something you'll have to test out and see how much room each will require to achieve your goal.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
That sub is only rated at 55rms ported or free air and 100rms sealed
So I would like to think 75rms would work
And if I need more mid could I just use both 6.5 parell getting 40rms each
So each door has a 8" on 75 and 2 6.5 on 43rms
That way it should allow me to turn down the mid if required
I'm not aiming to keep up with anything sub wise as I have none
I have a kicker zx700.5 and can't fit anything behind my rear seat 4door Toyota truck
I brought a 10" 2ohm kicker cvt sub in kicker box and it didn't fit so I borrowed a friends kicker 8" slimline sub in kicker box and no fit either
I have approx 4" bottom 12" high wedge to work with
So looking to get something better bass wise in my doors as I have little options to add subs
I also saw they are realising a 2ohm version so if so I would have access to 85rms if it helps
All I have equipment wise at moment
Pioneer 2650 h/u
Kicker zx700.5
2 sets kicker ds650.2 comps still in box
4 gauge power and 3 sets rca leads
Front doors deadened with dinamat
4" square 2way kenwood speakers in dash (stock location
I have a mate with the same speakers on a cx300.4 getting 40rms a speaker
And for $50 a set delivered there not to bad for stock setup just no bass that all
Before i got my subs in my last car i went through many brands and types of speakers to find ones that had the bass i was looking for.
The best sounding ones were.
Polk Audio - http://www.sonicelectronix.com/item_14715_Polk-Audio-MM691.html
Damn good speaker that sounded good and had great bass output, but had an achilles heel in the surround that would tear from the extreme excursion the speakers would get with high amounts of power being fed to them at full range.
JBL P660c - http://www.sonicelectronix.com/item_12260_JBL-P660C.html
Excellent comp set for the price that can do everything you want at a budget that won't break the bank, they also suffer the same problem the polks do in tearing the surround with high amounts of power at full range.
Hertz HSK - http://www.woofersetc.com/c-172-speakers/c-10-compon-speakers/c-40-65/p-11726-hsk-1654-hertz-65-250w-peak-2-way-component-speaker-system.html
By far the best set of comps i have ever owned and did everything beyond expectations, they are well worth the money you'll spend on them, and as long as you do not go full range with insane amounts of power, they'll last a very long time. The triple joint tore at the spider and when i tried to glue it, but the gap was wide enough that the glue leaked down into the speaker ruining one, unhappy camper here.
Simply put you want a sub stage, cause if you try to play full range and play down to 40hz, you'll only spend countless amounts of money on speakers like i did, learn from my experiment in futility
The amp that did the damage to the speakers was an old school ppi pc2600 @150w ch@4ohm that put out much more than that.
Quality equipment makes all the difference in the world.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Argument of placement....or even doing it aside....CompRT would be the woofer for the job. They make both a 6.75" and 8" version both DVC and both available in 1 or 2 ohm flavours. And they'll handle 3X the power while being more shallow yet. MUCH more suited for a midbass.
I think your best option would be to find a spot for a shallow sub. There are some good shallow subs. You don't have any space under the rear seat? Have you measured either under or behind your seat?
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
The car I have a ln106 with a custom flat tray in back
The car is very narrow and has no spec in rear
I have tryed to fit a cvt10 shallow sub and cvt8 behind rear seat with no success
The only thing that fits is a one of thoes 2" high compact sub amp combos that focal make
Due to the $$$ and shipping cost
I'm am very limited
http://www.customcar.com.au
This is the only imported and they distribute to to a vast number of auto chains, if you look on there site you will see there rrp prices and how limited our stock is of each brand
And see how good you guys have it over there
My zx700.5 is a $750 amp new and getting 350-400 secondhand
Normally I would buy online but with $1.30 buying $1us then the 10% import tax and shipping fees
It makes your Polk speaker that are on sale on sonic for $139 +127 shipping $266 then the $$$ and 10% tax take a $139us to $380au
I have a friend that shipped a sundown x15 here
$700us in shipping alone for 1 sub when you do the maths a x15 in Aus is a 1900 sub
All I want to do is add a bit more bass to the car without breaking the bank and doing it with no subbox
I did think about doing a centre console built as I have 5" between my 2 seats but after measuring I have about 13liters 0.4cuft with no sub using 1/2" mdf
I have seen 4" house/computer subs used there before in factory console
If I was to go the 6.5" compRT would that be a better option
I do have the sub Chanel spare on my zx700 210rms or 420@2ohm
But I think in my doors I would want stereo not mono sound?
The sub channel output of your source unit and sub channel on a 5-channel amp is mono by nature.
  • Who's Online   0 Members, 0 Anonymous, 999 Guests (See full list)
