pipe atachment??
dsw422
Hey guys, I'm building a box with some pipe ports for the first time. I'll b using 3 or 4 inch pvc pipe. How do yall get it to stay put?? There will be no flared ends, and I'll be mounting to mdf.. what kind of pvc do u recommend also??
Thanks guys..
2014 Ford Focus SE Sedan
Factory Sony 10 Speaker Sound System
1994 Ford Bronco
Dual head unit (i kno)
Sony door speakers
Kenwood Rear Speakers
Custom Center console in the works. will house an NVX NSW10"
https://m.facebook.com/WinnsCustomCarAudio/
I use my router and circle jig to route a circular slot about 1/2" deep for the pipe to fit into. Then I glue it in with epoxy. After it has cured a use a flush trim bit to cut the inside flush with the inside of the pipe. Works great.
Builds:
Thanks guys for the input.. I think I'm going to go with ur idea triticum. But with a little diffence. I'm going to route a hole for the pipe all the way thru. Then I'll use another layer of mdf and flush trim that to the pipe, and then roundover to look sorts like a real flared port..
Only other question I have is would gorilla glue sufficient for glue??
1994 Ford Bronco
Sony door speakers
Gorilla glue should work. I'd suggest you rough up the outside of the pipe for better adhesion.
Builds:
You need to consider the length of the port, if too long better brace.
Thanks triticum.. will do..
Joe X, port length will be 6 or 7 inches (havnt decided yet).. any bracing for that length??
1994 Ford Bronco
Sony door speakers
  • Who's Online   0 Members, 0 Anonymous, 605 Guests (See full list)
