Black Beauty Project Build - 06 Ford F-250 Super Duty **1/27/18 - New pics starting on page 41**
Build looks killer so far!! If you're looking for the dual alt bracket for the truck, and you haven't searched it already, check for the snow plow prep package bracket. That'll usually be the part you need for duals.
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
Your work is insane. Looks great man. Remember if you need any diagrams or anything hit me up on fb
Thank you. I think I'm good for now with the ideas I have. I don't think I'll need to re route anything.
Thank you. i'm not sure yet if I'm going to do duals or not. I probably will down the line, but it's not high on the priority list. No money for amps or batteries at the moment so I'm a long way from there. And with this alt and the power I have, I'll be fine for the current projects. I will look though because I want to make sure the option is there. They're just kind of hard to find is all.
Thanks for the heads up.
I have more pics from last nights work. I had an idea on the way home from work, and it took off like wildfire!! Very excited about this. Of course I'm easily excitable if that tells you anything. HAHA. I'll post pics in a little bit.
Ok let's get this party train rollin!
There are a few mix ins here. I needed to get an idea about sizing on the ends and the back panel for the SDU.
So I decided to do some R&D on the AA2000.1.
11225078_310181399105809_483156852868357
Checking out how the panels are put together and on. Would love to take these off and use them to make a template, but I don't want to risk messing anything up on this thing. So I'll make it from scratch.
11988701_310181412439141_604394844935880
A couple of screws, and the rca nuts holding the panel together. Notice the two tapped screw holes on the top. Those are for the back panel screws.
11202816_310181429105806_594431866681014
Thickness of the end panel. The back panel isn't as thick as this. I'm guessing maybe around .6mm or even .5mm. So the end panels need to be pretty stout to hold the back panel and board etc. In the amps case anyway, probably not the case with the SDU.
11951129_310181439105805_174293566199356
I found a scrap piece of 1/4" mdf for the end panels template.
11988421_310181459105803_470208498462076
Ready to trace the interior of the unit. I'll trace this out to give me an exact cutting mark.
11836838_310181475772468_815618141188654
After I did this, I realized I need room on the bottom of it to have the bend for the back panel. With the rest of it, I can just add a half inch where I need it longer and draw it out.
11953214_310181495772466_903668886469252
With the measuring and testing and such done, I decided to throw some paint on one of the cut off pieces to see if I can get a decent match.
11218794_310181515772464_241952677984871
Here it is wet. I'll have to wait until tomorrow to see what it looks like dried. The edges are a bit rougher than I thought they'd be, but I probably won't worry about it. I'll try to leave it be. I could use some filler primer, and that may smooth it out a bit. I'm guessing I'm not gonna get too smooth without some serious work.
11951275_310181532439129_892583308631824
That was all I did Sunday. Recall I said I have a few pics, but nothing special. There they are. I forgot to check the case last night. I'll make sure to do it tonight and see what it looks like.
Last night my mind was on something far more interesting having to do with this project!!
Time to check out the remote part of this project. I was on my way home from work yesterday and I was thinking, as I always do stuck in rush hour traffic. And then it hit me!! We'll get back to that part. But here are the tools I'll be needing tonight.
11947407_310181549105794_307248010008856
First, the volume knobs. These are Axxess volume knobs, much like the LC-1. These are what I'll be using to do this project.
11947420_310181575772458_882494928907678
But this is what hit me. A couple of years ago I bought two of these SMSL headphone amplifiers. Nice units. Cheap at the time, I think I paid $25 each or for both I can't recall. Anyway, it is real close to the perfect size. So we're going to gut it and see what happens.
11008054_310181589105790_659904928069532
Rear. RCA input, speaker connection outputs, and a power port.
11223635_310181609105788_564492229330272
Let's take it apart. Start with the volume knob, just slides off, and then loosen and remove the 4 screws.
11988593_310181632439119_623948777474987
Next remove the nut and washer.
11224423_310181645772451_211369962556058
Then pull it off.
11937432_310181679105781_546395976269236
11825919_310181695772446_563386793835786
The rear is a little different. Smaller headed screws. Also a screw on the rca jacks.
11954787_310181709105778_276453056581597
10436187_310181725772443_692657500667882
Remove the speaker terminal tops. In hind sight this didn't have to be done, but I was trying to figure out how they came apart. So I did it.
10383102_310181742439108_692390856159906
Then the 4 outer screws.
11988671_310181759105773_627039773061450
Slide it out and you have the board.
11924917_310181779105771_842587427627911
Unfortunately I had to kind of get a little rough with it. The bottom speaker terminals are soldered directly to the board. The upper speaker terminals are soldered to a separate board, and then wire soldered to the main board. So those will have to be removed in order to get the speaker terminals off of the end piece.
11953114_310181802439102_231032549346867
11925999_310181815772434_172307391123846
Now this is all I'll use for this project. The rest is pretty much trash.
11987119_310181839105765_853117479001456
Now I need to take these apart. Obviously they won't fit in here with the shells on them.
11224230_310181859105763_673107691349554
Remove the knob
11052371_310181882439094_981107743873066
Nut and washer
11954729_310181895772426_893059880300200
There are a couple of tabs that hold it all together. One on top and bottom for each the front and back panel.
11954803_310181912439091_154137194061123
Push the tab and pull it out.
11951206_310182142439068_283480668123002
Apart and ready to move on.
11988696_310182152439067_657507636995837
A little peak at the board.
11225078_310182162439066_722071641523811
11988600_310182179105731_743390657055785
10448735_310182202439062_120084796274663
First I removed the hot glue. Now I can see it much better. There's an in side and out side. It's labeled as well as the wire spots so these can all come off.
11933462_310182229105726_236228391606498
Grounds on the outside, left and right in and left and right out on the inside. Well why did I cut the wires off if I'm going to need them you might ask. Because I need to solder hard wires on so that I can also solder them to the connector for the cable that will run from the remote to the SDU. The RCA's were too big to be used. The holes need to be cleaned up on the boards, but I didn't have my soldering gun so I'll be sure to address that later.
11924259_310182252439057_771494927081587
The leftovers. 1 down 3 more to go.
11923263_310182265772389_170886773158519
Here are the four knobs and boards, naked and ready to be put in their place.
11947455_310182285772387_265216388226799
I put the boards side by side to get an idea of the width and put the case in behind them to see about the fit. It really fits well as far as I'm concerned. After I get the layout just right, I may ca glue them together so they'll be one board, even though they're really 4 separate ones. It'll make things easier when I go to put it all together.
11987194_310182295772386_144452269223002
That is gonna work out real nice. I was originally going to put a power led in here, just so if there was a problem with power I could see it up front. But I don't really think I'll need it. Plus it looks like it'll be a little tight in there at this point. I'm actually a little concerned with the fit. I can bring the boards off of the bottom of the case and I'll also be wrapping them in foam tape. However, where I'm concerned is the top of the knob housing itself. It's metal, and then has two boards sandwiching it, see picture above. My concern is that metal part touching other metal. Not sure what issues that might cause. I may have to hook it up and see what happens. Maybe I can tape some thin plastic over them like you see in amps and other electronics.
11949530_310182315772384_160554670397586
Side view.
11052371_310182332439049_492665371504031
Here is a little look at the amount of room in the case. Lots of it. Probably don't need half of this. But we'll see. Knobs were there just to hold them down, they kept tilting forward.
11899873_310182355772380_794765292691458
Now I need to tape it up and do some measuring and marking to figure out where to cut this thing at.
11222015_310182379105711_762094934281685
11947520_310182392439043_233777059461393
11933458_310182409105708_592162946713750
I'm using the original face plate on this. It's nice and thick, but I have some plate this thick or there about so it will give me a good idea of depth.
11960120_310182439105705_594072301062342
That should be about it, to the end of the boards.
11896167_310182455772370_668088541872236
Then I measured the total depth of it. Took half and that's where the line is at to cut. Should be plenty of room.
11986975_310182469105702_404645799497955
Next I'll have to explore a couple of things with the boards, put them together, get some wires soldered on and see where I'm at. I may also have a connector that I can use, so I could get the whole thing wired up and get an idea of how much depth I actually need before cutting the case.
So that's what I did last night. I'm not sure how much more I'll be doing this week. I have to get ready to go on vacation for a few days, leaving Thursday Night. I may not get anything else done before then.
That's all for now. Thanks for checking this out.
very very interesting. Love seeing parts taken apart and seeing the internals. Neat little project, should be really cool when its done
Fidelity
Built to Last
Team Sound Asleep
24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/
2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3
2 DD M3b
Maxwell 2.7V 3000F Supercapacitors
Pioneer DEH-80prs
Focal P165 V30 components
Rockford Fosgate T-400.4
If you want to pm me your entire VIN with year make and model, I'll contact my buddy at the ford dealer we service and see what would fit exactly, if anything. That way you can have the exact ford part number
Currently Own
2 - DC 5k
lvl 4 motor
lvl 2 motor
