SPL box design questions/help
sbg
Hi had a few questions on a spl box. Just for fun I want to build a box just for numbers. I know a Lot of testing goes in to finding a good box. But was thinking others could point me into a good starting point.
Equipment.
1 hcca 12" d4
Orion txr3700.1
It's a 2001 ford,focus se
My amp does 2400wrms at 2ohm 12.6v
So sub will be getting full rms.
should not have to bad of volt drop at 2ohm also.
As of now I run 2 hcca 12s in a 2:1 4th order in my trunk and does ok. 146.db sealed and a 148.7 outlaw. Cars peak is 44hz.
Should is start off with sub and port firing forward? And go with a mid 40hz tune? in a small box?
Take Whatever help you guys got, thanks
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Not enough port area, IMHO. The higher you tune, the more port area you need. Since all your output around tuning comes out of that port, you don't want to restrict the flow at all. I'd use two 6" ports.
Builds:
If both drivers fit in a bandpass both will fit in a ported, larger box shorter port for a given tuning, I would probably go for a variable tuning psychoport, for sure you will need to tweak tuning , use Small's estimate to calc port area at the tuning range you intend to be at. Much of SPL boxes is vehicle dependant so continue your research.
  • Who's Online   0 Members, 0 Anonymous, 2377 Guests (See full list)
