Jordan Thurston Posted May 22, 2015 Report Posted May 22, 2015 Hey guys I just got my alpine mrx-m240 back from alpine swapped my alpine mrp-m2000 for it the m2000 was cutting out at high volumes so I sent it in ended up having thermal damage they couldn't fix it so I upgraded to the m240 still having the same problem. I think it is voltage related I can turn it up pretty loud without it cutting out but it will still cut out on some bass notes seems to be lower notes doing it.when I say cut out I mean it just stops putting out any sound it still is on but no power to the subs I have the stock 120 amp alternator agm under the hood and 2 smaller agms in the back I don't think the 2 smaller agms are doing much. What I'm wondering is Would just getting a xs power d3400 stop this voltage drop issue or do I need a high output alternator to ?
audiofanaticz Posted May 22, 2015 Report Posted May 22, 2015 What ohm load is the amp wired at? You said that both amps where doing the same thing? Really 2000-2500 watts is not to hard to support with minimal electrical upgrades. I would go through all your power and ground wires making sure all connections to the batteries are tight, make sure any fuses are tight, make sure you have a good ground to bare metal. Id also make sure your gain is properly set as well.
Jordan Thurston Posted May 22, 2015 Author Report Posted May 22, 2015 2 ohm load the hifonics amp I had in there works perfectly fine and I had 2 of those in there at one point and never had an issue its really frustrating me I've spent 500 now on the amp and still is cutting out on me I will check my grounds and all my connections and see if it helps
Jordan Thurston Posted May 22, 2015 Author Report Posted May 22, 2015 Just looked over my wires my ground wire looks like it's a little lose in the ring terminal so I'm going to take it out and redo it and hopefully thats my issue
catch 22 Posted May 22, 2015 Report Posted May 22, 2015 I have the same amp. same shit was happening to me. And I had a d3400 under hood. Upgraded my alt and it plays fine
Jordan Thurston Posted May 22, 2015 Author Report Posted May 22, 2015 I checked all my grounds and it's all fucked up my batteries tipped over the other day I never looked at the wires but all the grounds were about ripped out I'm going to re wire it all tonight
Jordan Thurston Posted May 22, 2015 Author Report Posted May 22, 2015 I have a decent agm battery under the hood so I'm debating on either a d3400 in the back or just doing an alternator not sure what to try first
Jordan Thurston Posted May 22, 2015 Author Report Posted May 22, 2015 Would a 220 amp alternator be ok or should I go with a 270 amp ?
Afficionado Posted May 22, 2015 Report Posted May 22, 2015 I told you multiple times in the last thread that it is a voltage issue. These amps are really inefficient. Consider a high output alternator or bigger battery reserve. If you have any questions relating to nutrition, lifting, or health in general, feel free to give me a PM and I will give you straight forward advice with no BS involved.
