Quiet4Lyfe Posted May 23, 2015 Report Posted May 23, 2015 Alright guys, hows life, awesome anyway i have to get something clarified and worked out here sooner or later or i am going to go insane. I've been building boxes for quiet some time now, using torres of course, and i haven't paid much attention to number of common port walls, ive always put a 3 in there not really caring.. I've seen the entire thread on common port walls. and my dumb self is still confused.. So i made a little diagram in paint that took me a whole 10 minutes to make. Please, if you can.... Please reply with the diagram number followed by the correct number to place into torres. thank you It's about to get QUIET. Expedition, Quad zv.4 18's, ab750.1, quiet mode activated... Visit our build log at : http://www.stevemeadedesigns.com/board/topic/197481-expedition-quad-zv4-6th-order-attempt-first-time/
Andrew Storlie Posted May 23, 2015 Report Posted May 23, 2015 for those reading this post after my post PLEASE correct me if im wrong... but i dont think the # of common walls is as important as the port length. if your port needs to be 30" long and it requires 3 walls to make that length, then 3 walls is the best. if its only 9" long and you need 1 port wall, then thats the best.... first figure out you port area per ft^3 net volume... then use that to calculate length for your desired tuning. then figure out the total volume of your port, internal box ft^3 and displacement of your port walls, bracing (if any) and sub. add all of that up for a master volume of your box. then use your max dimensions to figure out your box size and shape... EDIT: i have heard that the more bends you have in a port, the worst off your going to be...
Broke_Audio_Addict Posted May 23, 2015 Report Posted May 23, 2015 All of those diagrams have 3 common walls. To clarify it means how many walls does the port share in common with the rest of the enclosure and in all those designs it shares the right, top, and bottom. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
afrakes Posted May 25, 2015 Report Posted May 25, 2015 All of those diagrams have 3 common walls. To clarify it means how many walls does the port share in common with the rest of the enclosure and in all those designs it shares the right, top, and bottom. I've never fully understood this either, so correct me if I'm wrong now. But the second picture looks like it also shares the back(4 walls) and the third adds in the left side (5walls). Vehicle: 2014 GMC Sierra 2500HD WT Head Unit: Pioneer DEH- Mids/Highs: Focal Integration ISC 165’s (front) Subs/Amps: TBD
OrionStang Posted May 25, 2015 Report Posted May 25, 2015 Its all explained in the HELP section on Torres' calculator, as well as all over the webz. Zero port walls shared http://www.google.com/imgres?imgurl=http://img855.imageshack.us/img855/6474/independentport.jpg&imgrefurl=http://www.stevemeadedesigns.com/board/topic/38791-torres-box-tuning-calculator-updated-818/&h=533&w=800&tbnid=_37EnG0-jbHabM:&zoom=1&docid=frfkNUx_dzmgxM&ei=L5hjVcGDDI73oASgnYLQAw&tbm=isch&ved=0CB0QMygBMAE 1 port wall shared http://www.google.com/imgres?imgurl=http://img341.imageshack.us/img341/9939/bottomportbox.jpg&imgrefurl=http://www.stevemeadedesigns.com/board/topic/38791-torres-box-tuning-calculator-updated-818/&h=734&w=1090&tbnid=hjTD4s9_5BtvsM:&zoom=1&docid=frfkNUx_dzmgxM&ei=L5hjVcGDDI73oASgnYLQAw&tbm=isch&ved=0CBwQMygAMAA 2 port walls shared http://www.google.com/imgres?imgurl=http://i934.photobucket.com/albums/ad189/lilsoccersully/IMAG0156.jpg&imgrefurl=http://www.soundsolutionsaudio.com/forum/topic/55413-12-inch-zcon-sounds-blown-at-higher-freq-could-it-be-the-box/&h=576&w=1024&tbnid=YqvDmjNBd0nkOM:&zoom=1&docid=PBjH7jaKRgSKeM&ei=L5hjVcGDDI73oASgnYLQAw&tbm=isch&ved=0CCQQMygIMAg 3 port walls shared http://www.google.com/imgres?imgurl=http://img246.yfrog.com/img246/6968/slotportbox.jpg&imgrefurl=http://www.stevemeadedesigns.com/board/topic/38791-torres-box-tuning-calculator-updated-818/&h=741&w=1100&tbnid=J1kH78KphOBn_M:&zoom=1&docid=frfkNUx_dzmgxM&ei=L5hjVcGDDI73oASgnYLQAw&tbm=isch&ved=0CB4QMygCMAI SMD Super Seller My Feedback Thread
