Joe Kralovetz Posted May 27, 2015 Report Posted May 27, 2015 Anyone have any exprience with the Sundown Audio X 12" sub as to which box specs work best with it? I have (1) X12 sub running on a 2416.1D Hifonis amp at 2 ohms. in a prefab vented 2.6 cubic feet box, sounds alright but, the box isn't very good and I'm sure a custom box would sound much better. I'm looking for that really deep low bass as well as spl. 2007 Chevy Equinox Pioneer AVH-X5800BHS Big 3 2 runs of 2/0 Welding cable 2 - XS Power D3400 Batteries in Parallel - Fused at 250A Alpine MRP-2000D - Temp amp. 1 - ZV4 15" Rev 1
Joe X Posted May 27, 2015 Report Posted May 27, 2015 Post your box measurements inside and out to see where you are at, most prefabs will have low port area.
Joe Kralovetz Posted June 10, 2015 Author Report Posted June 10, 2015 The port is way off I can tell just by loooking at it. Specs for the box are as follows: Rockville RBS12 Single 12" 2.6 cu.ft. SPL Vented/Ported Subwoofer Enclosure Box¾" USA Heavy Duty MDF ConstructionType of Enclosure: VentedDimensions in Inches: 14.75" L x 30" W x 14.75 H"Top and Bottom Depth: 14.75"Mounting Depth: up to 10" (enough depth for any sub on the market)Gross Volume Per Sub (Measurement for the outer dimensions of the box): 3.7 Cubic FeetNet Volume Per Sub (Measurement for the outer dimensions of the box less the thickness of the wood): 2.6 Cubic Feet Sorry been awhile since I had free time to pop on late response. 2007 Chevy Equinox Pioneer AVH-X5800BHS Big 3 2 runs of 2/0 Welding cable 2 - XS Power D3400 Batteries in Parallel - Fused at 250A Alpine MRP-2000D - Temp amp. 1 - ZV4 15" Rev 1
Joe Kralovetz Posted June 10, 2015 Author Report Posted June 10, 2015 2007 Chevy Equinox Pioneer AVH-X5800BHS Big 3 2 runs of 2/0 Welding cable 2 - XS Power D3400 Batteries in Parallel - Fused at 250A Alpine MRP-2000D - Temp amp. 1 - ZV4 15" Rev 1
Triticum Agricolam Posted June 10, 2015 Report Posted June 10, 2015 While it seems to have decent port area, just looking at the port I'm guessing that thing is tuned somewhere in the 40s, no wonder your low end output isn't very good. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Joe Kralovetz Posted June 10, 2015 Author Report Posted June 10, 2015 Says 37 hertz in the specs ( prefab junk so who knows) it hits pretty deep and hard. I just know it can sound better in a better box. 2007 Chevy Equinox Pioneer AVH-X5800BHS Big 3 2 runs of 2/0 Welding cable 2 - XS Power D3400 Batteries in Parallel - Fused at 250A Alpine MRP-2000D - Temp amp. 1 - ZV4 15" Rev 1
Joe X Posted June 11, 2015 Report Posted June 11, 2015 You can try to increase the port length to lower tuning, if you could measure the port width and depth it would be easy to see what's the tuning, Sundown tunes to 32Hz.
Joe Kralovetz Posted June 12, 2015 Author Report Posted June 12, 2015 I'll do that after work, and post back here. 2007 Chevy Equinox Pioneer AVH-X5800BHS Big 3 2 runs of 2/0 Welding cable 2 - XS Power D3400 Batteries in Parallel - Fused at 250A Alpine MRP-2000D - Temp amp. 1 - ZV4 15" Rev 1
Joe Kralovetz Posted June 15, 2015 Author Report Posted June 15, 2015 3 1/4 width X 13" height X 13.5" deep into the box 2007 Chevy Equinox Pioneer AVH-X5800BHS Big 3 2 runs of 2/0 Welding cable 2 - XS Power D3400 Batteries in Parallel - Fused at 250A Alpine MRP-2000D - Temp amp. 1 - ZV4 15" Rev 1
Joe X Posted June 15, 2015 Report Posted June 15, 2015 With an X15v2 in (0.23 displacement) it comes to ~2.3 net @~49.8 Hz with ~ 43 square inches of port area. Well not many lows from that.
