cj120 Posted June 6, 2015 Report Posted June 6, 2015 Hey there guys, got some questions for ya'll, considering buying a 10" in either of the Fi audio X series or the Ascendant audio Chaos Series. I know they are basically the same, and the manufacturers recommend 0.6 cubic ft to 1.2 cubic ft @33hz, My questions are at which box Size will it sound loudest?(smaller or bigger or medium size) and will it suffer if i make the box bigger than the recommended specs? and also what if i make my box design with a longer length than width, would that affect anything as well? i'm new to these kind of things so any advice would be greatly appreciated thanks.
Joe X Posted June 6, 2015 Report Posted June 6, 2015 Speaking of a ported box, around tuning the larger box is going to be more efficient than the smaller one, at least if the port is working right. What feels louder is more complicated than that.
Miguels Posted June 6, 2015 Report Posted June 6, 2015 if you have the room to build a bigger enclouser just get a 12 my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
cj120 Posted June 9, 2015 Author Report Posted June 9, 2015 Ok i'll try to experiment with a bigger size box, and if the Fs of the speaker is 32Hz should i tune it so low, or should i go a little higher than that? around 35-37hz maybe?
Triticum Agricolam Posted June 9, 2015 Report Posted June 9, 2015 Depends on what your goals are and what kind of music you listen to. The Fs of a sub is its free-air resonance, once you put it in a box it changes anyway. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
cj120 Posted July 19, 2015 Author Report Posted July 19, 2015 Depends on what your goals are and what kind of music you listen to. The Fs of a sub is its free-air resonance, once you put it in a box it changes anyway. you know anyone who is good with torres box calculator? i'm trying to design a 1.6 cubic ft enclosure @36hz
