Tahoe Battery Current Sensor
  • 3 weeks later...
  • 4 years later...
Sorry to bring up an old thread but this is the best info I’ve found on this. If you add a battery, would you still run a power to the front and ground it in the back to frame/body and be ok?
Pioneer AVH-P4200DVD
Rockford Fosgate T5001 bd-cp
2 DC level 2 12's
Focal Access Components in the front
Focal Access Coax in the rear doors
Rockford Fosgate Punch Boosted Rail 4 channel rms 4x75
XS Power D3400 under the hood
Knuconceptz Ultra Fleks Power & Ground
Ya I had a few batteries in the back with frame grounds back there and it was fine. As for the front I just replaced the stock ground with one run through the sensor. The sensor is big enough to fit one 1/0 run with the headlight ground going through also.
  • 6 months later...
In my 07 Suburban, I already had the big three done, Mechman Alt. I ran 0 gauge through the current sensor, when I start my truck I get get 15.0 volts for a few seconds then I am assuming the RVC knocks it down to 13.8, with all the various ways and workarounds, I think the best bet for my situation is a secondary alternator dedicated strictly for audio. I just did a battery delete up front and now on straight lithium only. I have been told that Lithium cells like higher than average charge 15+ volts.
2006 Nissan Titan Crew Cab
XS Power D6500 up front, Mechman 270 amp alt,
Front Stage:Hybrid Audio Legatia Tweeters and Midrange drivers in Custom A Pillars, HA Unity 6x9 inch Midbass in the doors, powered by an Arc Audio 1200.6 X2 and connected to a JL TWK 88 DSP
Subwoofers: Four 8 inch Soundqubed Subs in a ported enclosure. Incriminator Audio 20.1 on the subs (@ 1ohm)
Performance: JBA Headers, Uprev Tuned, Dynomax bullet muffler, 3 inch exhaust all the way back. Air raid CAI.
Wheels: 18 inch Balistic Jester wheels on 33 inch Nitto TG2's
Suspension: 6 inches of lift total. DK UCA's, DK LCA's, Icon coilovers up front, Bilstein Shocks in the rear with 4 inch blocks
2007 Chevy Suburban LTZ
Engine: 5.3 DOD Delete, BTR Stage 4 truck Cam, TSP Headers, Gibson Catback exhaust. Tuned by Sam @ Advanced Modern Performance.
Suspension: 2/4 Belkin drop. Belkin Sway bars, Spohn Panhard bar
Audio: Pioneer 8400 NEX Head unit, Audio Dynamics DSP, 6th order enclosure with three 10 inch DC Audio Level 4s behind the third row. Wolfram 4500 on Subs, Wolfram AW 250.4 on the front stage Dual SkyHigh Car Audio 8 inch mid bass in the doors, quad 3.5 inch midrange drivers in the A-Pillars
Dual Alternators, Mechman 320 powering a CES 40ah Lithium battery, OEM alt has an AGM on it.Viper remote start.
Wheels:  24 inch Luxx wheels/ 305/40 R24
Grammatically speaking, Prolly is not a word.
  • Who's Online   0 Members, 0 Anonymous, 1500 Guests (See full list)
