Pictures of YOUR tee nuts/barbed inserts in use
dsw422
If you mount your woofers facing up (cone to the roof), they are not that bad. When you mount your woofers horizontally, you will have a bad time, regardless of if the are 20lbs or 70lbs.
Just use #10 spax and call it a day if it is for woofers.
My 2 cents would be to only use them where you have a good amount of room to work and where you dont need to hold 40 lbs up while you put them in.
For holding a window or panel on, they aren't that bad, but i would go the route posted above with the links.
Thanks for the info.. I guess I'll ask everyone for pics of barbed inserts being used..
2014 Ford Focus SE Sedan
Factory Sony 10 Speaker Sound System
1994 Ford Bronco
Dual head unit (i kno)
Sony door speakers
Kenwood Rear Speakers
Custom Center console in the works. will house an NVX NSW10"
https://m.facebook.com/WinnsCustomCarAudio/
Good plan, I will never use them again in an application where I can't reach the backside. The damn barbs never stay put and then it just spins when you try to remove the screw, leading to hours of trying to get them far enough out that you can get a hacksaw blade in to cut them. Fuck T-nuts!
2008 Subaru WRX STI
K&N Typhoon Intake
Invidia Polished Stainless 3" turbo back with cat
Cobb Accessport
Dyno tune from Kaizen Tuning
320awhp 330ft-lb awtq
MTX 421D Sub amp
American Bass SQ900 Highs/Mids amp
Sundown Audio SD-2 10 D4
JL Audio XR653-CS 3-way Components
3sixty.2
Second Skin Damplifier Pro
Custom fiberglass wheel well enclosure
Transmission Line quasi-floor enclosure
http://www.stevemeadedesigns.com/board/forum/13-member-rides-builds-show-off-your-whip-show-off-your-system/
Bill Fitzmaurice TLAH line-array hifi towers
9 Goldwood 4" mids (each)
12 Goldwood 1/2" tweeters (each)
NAD 1020 Preamp
MiniDSP 2x4 Balanced processor
Thorens TD166mkII Turntable
Hafler DH-200 Amplifier
http://www.stevemeadedesigns.com/board/topic/192638-line-array-hifi-tower-build/
https://www.facebook.com/HolyMountainGlass
I put mine on the backside of my baffle, so they don't have the potential of ripping out the frontside.
I wanted to use M6 bolts to hold my subs since I didn't want to take the chance of my MDF baffle getting stripped out from screws.
They've functioned well in that regard as I've had my subs in and out a few times.
BUT, like most have mentioned, if you cross thread one.....its DONE.
A BITCH to get back out. Happened to me on one occasion.
So you have to be very careful when tightening the bolts that they don't tighten up and cross thread.
Had a rivet-nut do the same thing to me in my trunk.....almost ripped the whole trunk lid off in frustration.... O_O
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
Best way to use a tnut I've found is sandwich it between layers of the baffle if its for the woofers. Can't back out or spin unless the barbs snap off. For inserts use woodglue or some adhesive or epoxy when you put them in. They set up very sturdy. Should have no problems. I had threaded inserts holding my Fi BL18 at an angle that broke screws left and right. Inserts never backed out or stripped.
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
how about some adhesive on the tee nuts?? should work the same.. ill probable go with the barbed inserts though.. for the box im getting ready to build, ill need about 40!! lol
im going to use those cam locks next time i build a box.
?? like for cabinet drawers??
1994 Ford Bronco
Sony door speakers
Idk if I'd trust the barbed inserts. Looks nice tho. I just do a course thread insert with #10 or 1/4" inner threads. Screw in from the top where the sub mounts to. Never had them back out even without glue. They were very secure.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
gotcha.. ill weigh my options between the 2.. hell i may even use both.. lol..
In case yall were wondering, ill be using the fasteners to put together a 4th order in a crown vic.. ill be building it in a week or so.. its 4 parts...
sealed box
ported box
port
access panel (mdf)
heres the three main pieces..
and here is what itll look like put together..
1994 Ford Bronco
Sony door speakers
  • Who's Online   0 Members, 0 Anonymous, 2128 Guests (See full list)
