Areo ports
rsfm089
2003 Ford Taurus I can take measurements later I think I actually have enough room for two hdc3's this time I was just going to use the box I built for my truck but it's to wide
Hopefully you do, any pics of the trunk are welcome. Your amp will need to be a good one in the 4K range to get what those can deliver.
39w24L15h subs front port front two hdc3 12's on two aq2200's strapped at 1ohm car is a 2003 ford Taurus going for daily pounder want to hit lows
Here is a suggestion port / subs forward, sealed off, power: to 4K, amp subsonic filter to 28Hz, minimum port clearance 6", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
  • Who's Online   1 Member, 0 Anonymous, 569 Guests (See full list)
