dsw422 Posted June 20, 2015 Report Share Posted June 20, 2015 hey all.. does anyone kno if these amps are stable down to .5 ohm?? and about what is the power output (based on good elecrical)??? 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/ Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted June 20, 2015 Report Share Posted June 20, 2015 They are stout enough to handle a 0.5 ohm load if it has the electrical system to back it.... but do it at your own risk, they are rated down to 1 ohm only (meaning not warrantied down to .5). And what they do at .5 is anyone's guess. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
reedal Posted June 20, 2015 Report Share Posted June 20, 2015 You might get 100 to 200 watts at the most extra. Just buy an amp that does what you want it to at 2 ohm. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
dsw422 Posted June 20, 2015 Author Report Share Posted June 20, 2015 They are stout enough to handle a 0.5 ohm load if it has the electrical system to back it.... but do it at your own risk, they are rated down to 1 ohm only (meaning not warrantied down to .5). And what they do at .5 is anyone's guess. ok.. thanks You might get 100 to 200 watts at the most extra. Just buy an amp that does what you want it to at 2 ohm. ok.. i was asking cuz i have two dual 2 ohm 15s and those wired together is either 2 or .5 ohms.. i may try to get 2 q1-1200.2's.. how would i wire the amps if i ran 2?? 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/ Link to comment Share on other sites More sharing options...
moredbs Posted June 21, 2015 Report Share Posted June 21, 2015 They are stout enough to handle a 0.5 ohm load if it has the electrical system to back it.... but do it at your own risk, they are rated down to 1 ohm only (meaning not warrantied down to .5). And what they do at .5 is anyone's guess. ok.. thanks You might get 100 to 200 watts at the most extra. Just buy an amp that does what you want it to at 2 ohm. ok.. i was asking cuz i have two dual 2 ohm 15s and those wired together is either 2 or .5 ohms.. i may try to get 2 q1-1200.2's.. how would i wire the amps if i ran 2?? strapped at 2ohms Link to comment Share on other sites More sharing options...
dsw422 Posted June 21, 2015 Author Report Share Posted June 21, 2015 They are stout enough to handle a 0.5 ohm load if it has the electrical system to back it.... but do it at your own risk, they are rated down to 1 ohm only (meaning not warrantied down to .5). And what they do at .5 is anyone's guess. ok.. thanks You might get 100 to 200 watts at the most extra. Just buy an amp that does what you want it to at 2 ohm. ok.. i was asking cuz i have two dual 2 ohm 15s and those wired together is either 2 or .5 ohms.. i may try to get 2 q1-1200.2's.. how would i wire the amps if i ran 2?? strapped at 2ohms that'd be 1 ohm at each amp correct?? i should have each sub powered by each amp right.. im new to this strapping thing.. lol.. EDIT: NVM.. i just googled it.. lol 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/ Link to comment Share on other sites More sharing options...
