Alternator
You'll be fine.
do you even know what alternator his running?
if you have a regular alternator no it wont be fine. dont care if its singer or mechman, if its not hairpin your voltage will suffer at idle
what is the max output of the alternator. who is going to build it and is it hairpin? get a battery charger because you will need to top them batteries off almost every night
You'll be fine.
Assumed it was.
Based on the info he provided, it sounded like he knew his alt would put out around 200 amps.
But you are correct, if it's not a hairpin, he's going be dragging and those batts will be putting in a lot of work.
Singer Alternators
Team Asshole
#anothershittysingerbuild
yeah even my singer alt says it does 180a at idle but a soon is it gets hot my voltage drops to 13.4 to even 13.1 at idle with no gear.. heat is a big problem to alternators. if i throw air at it it starts to charge. i upgraded to hairpin and i see 14.8 at all times
The upgraded unit that I offer for your vehicle is a 260A/280A tested peak output before heat (160+A output at idle for a 800 rpm rotor speed on a 3-1 pulley ratio). This alternator is a direct bolt on design for your vehicle and would plug in just like the factory alternator (comes with overdrive pulley to boost idle output between 30-40A more then the stock size).
From singer
https://www.dcpowerinc.com/fit/Nissan~Titan~2009~5.6L-V8-VK56/11256-320-spx-i.html
That would be the only other option I have in alts.
notice where it says before heat.. go with hairpin if youre running 8k
also 160a does not comes close to 200a
The pulley adds 30-40a. Would that dc power would be the better option for me? Or is there a hairpin alternator for an 09 titan?
  • Who's Online   0 Members, 0 Anonymous, 925 Guests (See full list)
