dcannon729 Posted June 22, 2015 Report Posted June 22, 2015 The max dimensions for my vehicle have been reported as 16hx33wx34d. This is my trunk. I'd like to tune the box to about 32-33hZ. The specs of the sub: Fs: 33.4Hz Re: 1.8 Qms: 7.3 Qes: 0.5 Qts: 0.5 Cms: 64.2 uM/N Mms: 352.8g BL: 15.8 N/A Vas: 57.2L Sens: 87.6 1W/1m Le: 1.9 RMS: 1500 watts
Joe X Posted June 22, 2015 Report Posted June 22, 2015 So here is a suggestion for a trunk car, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3 1/2", figure is just an assembly guide: NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
