Home network help.
So, the router you have upstairs and the router in the living room will be AP?
If you're happy with the wireless coverage you get from the locations of your (assuming they'll be) AP's, then I'm happy. Everything else looks great!
Just pull extra lines where you think you'd need them the first time. PITA to pull a second time. Especially after furniture and what-not is put back in place.
Why the hell does your ISP control your Wifi activity? If the routers you're installing are for AP, don't even jack with your ISP. That's stupid.
2009 Dodge Caliber SXT (Silver)
Deck: Pioneer X3600BHS
Amps: RF P1000X5
Front: RF P16-S
Rear: RF P1694
Subs: 1 RF P3D2-10
Cabling: Stinger 6 channel RCA, RF 4gauge kit, SkyHighCarAudio 16gauge speaker wire.
Build Log: http://www.stevemeadedesigns.com/board/topic/188246-caliber-build
Professional Networking: https://www.linkedin.com/in/kade-mallett-332b8a104
Our ISP is gay. If I want the 2in1 router and modem. Otherwise it'll be part of the first pic with the modem the router separate then into the port of the 2nd. And the routers are new. Right now its just the single one. Coverage blows upstairs in my room on the far left side. By doing the 2 new ones I'm hoping itd help.
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
It'd burn a port on your patch panel, but you could go modem>patch panel>router>patch panel>switch> feeding the rest of your patch panel. It would save you a little bit of cash
Edit:
Actually burning 2 ports :(
Amps: RF P1000X5
Front: RF P16-S
Rear: RF P1694
Subs: 1 RF P3D2-10
If I cant get the 2 in one I'll just use the old netgear we have. And by going netgear with the rest I can just keep them all linked in and control them in one program. I'll just have a few short patch cables between everything. The new plan I did away with the patch panel. I'll just have the headlines ran straight to the switch. Cut down on connections.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
+1 on the netgear software.
I highly recommend having a patch panel though. Much easier to manage with than putting 45s on all the cables and it looks really clean.
I don't treat my projects and wouldn't treat this project any less than the guys treat their cars on this forum. Make it look good, make it work, take your time, and do a quality install.
Amps: RF P1000X5
Front: RF P16-S
Rear: RF P1694
Subs: 1 RF P3D2-10
So does it all sound good going off of the 16 port switch? Let's me add to the other rooms I wasn't going to also.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Your sketch looks perfect. 16 ports is more than enough to accommodate your entire home.
Only thing I can't stress enough is the patch panel. It's just the way I was trained and how I like to practice networking, but a patch panel will help out in more scenarios than one.
This would be an idea setup for me. Simple, clean, compact.
This http://www.monoprice.com/Product?c_id=105&cp_id=10514&cs_id=1051402&p_id=7255&seq=1&format=2
mounted to this http://www.monoprice.com/Product?c_id=105&cp_id=10516&cs_id=1051602&p_id=8623&seq=1&format=2
Put your equipment on a shelf just above the rack.
Amps: RF P1000X5
Front: RF P16-S
Rear: RF P1694
Subs: 1 RF P3D2-10
...Once you've crawled under houses through mud and cat shit, worked in attics @ 120 degrees in the summer, or just a simple fishing cable down/up a wall...You really don't want to do it again when a customer decides he/she decided to add a xbox next to their computer...
I got a call to run a line today...
In SouthWest Louisiana, everything stays wet. We don't have basements, and in my particular town, there are a lot of older homes without attics. Where do the wires get ran? Under the house :spiteful:
THIS is why you run more lines than you think you need.
Amps: RF P1000X5
Front: RF P16-S
Rear: RF P1694
Subs: 1 RF P3D2-10
I could definitely do that. Here is also the final list then.Screenshot_2015-07-09-17-13-54_zpsyxezm2Screenshot_2015-07-09-17-14-09_zps8xz3zrScreenshot_2015-07-09-19-51-06_zpspl35nh
Can anyone see something I'm missing or may not need? This blew the budget but i feel it will be well worth it if it all works. Went from like $200 ish to $270-350 so it better be worth it.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
You won't need any 110 phone jacks. Here's a tip, your standard telephone cable (rj11 and rj12) will plug into a Cat5e (rj45) jack. So, you can wire everything up the same exact way on the patch panel and at the wall plate on a Cat5e jack. Just depends what you plug into it. Dial tone or data. Backwards compatibility! :D
I'd just get 4 more Cat5e jacks.
You don't need the electrical precision cutters or the strippers. A cheap pair of throw-away scissors will work. What you want to do half-open your scissors and place the wire in it. Drag the scissors around the cable and score the insulation, don't cut through it. This will weaken the insulation enough for you to pull on the piece you want removed and it'll break at your scoring point. Exposing all your beautiful pairs.
Don't forget to use your T-568B wiring on both sides. Doesn't matter how you wire it as long as it's the same on both sides. For the sake of cable testers and the possibility a tech might have to work on your network, learn and use T-568B.
Other than that man. You are set up :good:
Amps: RF P1000X5
Front: RF P16-S
Rear: RF P1694
Subs: 1 RF P3D2-10
