Subwoofer Recommendations questions
i wanted to know which subwoofer brand is the best kicker or dc audio or any other brand??,
i have the following amplifier with me of 1000 rms
if i install a sub of more than 1000rms for e.g. 1200 or 1400 , will it under perform compared to a sub of exact 1000rms installed on MY amplifier(1000rms)????
money is it not issue please suggest good subs of 15 inch !!
and the 15 inch sub should be of 2 ohm or 4 ohm???what would be the difference performance wise??
To answer your first question, no versus threads.
Second, you can under power any sub and be ok. The more you under power it though, the less it will perform as it is designed to, so don't go getting and 3k+ rms subs. A couple hundred watts under powering is fine.
Third, how many subs do you want? One, two? If you only want one, then get a D4 voice coiled sub. The difference between the ohm loads is the wiring configuration, which will create different resistances that decide how much power your amp puts out. Your amp is only rated to 2ohm minimum, so your final impedance should be no less than two ohms
  • Who's Online   0 Members, 0 Anonymous, 878 Guests (See full list)
