catch 22 Posted July 8, 2015 Report Posted July 8, 2015 Finally got my shit playing (again) and now something is draining my batts overnight. Did some troubleshooting and couldn't find anything. So charged the batts and hooked em up, left them for a few hours and came back popped the hood and I could hear a faint high pitched wine (my head completely inside the engine bay). Looked around and it's the alt, it was warm to the touch and the engine is shut off. What could cause this? Any thoughts?
reedal Posted July 8, 2015 Report Posted July 8, 2015 Did you unplug the alternator to make sure 100% it is the source of the whine? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
reedal Posted July 8, 2015 Report Posted July 8, 2015 Second, make sure none of the batteries are connected to each other after you charge them, and see if maybe one of them is bad and draining the others SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
catch 22 Posted July 9, 2015 Author Report Posted July 9, 2015 Well the noise is definitely coming from the alt. unplugged it and it stopped. Not sure what's causing this. What else should I check? Or should I just email mike singer?
reedal Posted July 9, 2015 Report Posted July 9, 2015 Yep. Talk to singer. Something internally went wrong. I wouldn't use it personally till its fixed. Especially not if it's causing my batteries to drain. I would still disconnect all batteries from each other and the alt and see if they hold their resting voltage after a charge though. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
