Coil smell please help
yup its a gain issue ..ur pushing a 1200w rms sub with 500w ..the prx amps are 1 ohm stable so 1000x 1ohm 500x2ohm ..u must have just cranked it up til it sounded "good"..u cant set gains by ear .. use dd1
..u can also just buy a new amp that will do 1000 at 2ohms ..ur not even pushing wag that sub can do
You'd be surprised at how small of a difference it makes to add that much power. I have two of those subs, ran them on a 1200 (600w a piece) for two years, then moved up to the soundqubed 3500 this past December, wired at 2ohm 2600W, and while there is a difference in output with that 1400w increase, it's really not that much. The amp he's using pushes 750 @ 2ohm according to the rating, he doesn't need to upgrade his amp, the difference to a 1200 watt @ 2ohm amp won't matter given it will only ever see half of that real world.
How many cubes did you run with the 2 Hds312 and what were you tuned to? Just curious
2009 Chevy 2500HD
6" Lift
35" Nittos
22"x13" Fuel Kranks
Pioneer App Radio 3
Alpine 500x5
Memphis PRX 1.1000
Memphis Mojo5 12"
Red Oracle Halos
I still have mine in the same shitty prefab I've had for 3 or so years that I bought for some kicker 12's I had. I think it's like 3.5 cubes gross and tuned to 40hz. But it's wayyyy too small for the HDS312's. They need around 2.25-2.5 cubic ft net apiece. I just haven't built a new one. They work in this one decent enough, even though they need more space, and some of the music I listen to is bad for the enclosure tuning. They can get stinky around 33hz and less. Once I'm satisfied with the door pods, I'll build the enclosure next
  • 1 year later...
Thats the issue right there. with the proper box for those subs it should have been a night and day difference.
You need trunk space to get groceries and shit...bitches love groceries
  • Who's Online   1 Member, 0 Anonymous, 791 Guests (See full list)
