Deeznutz Posted July 16, 2015 Report Posted July 16, 2015 So since many of you guys run high output alternators, why isn't there a "sticky" for some sort of list of mods needed if any when purchasing a high ouput alternator?? If you read this and want to post up you car,engine,alternator ouput, pulley size, belt size, idler pulley size needed to make it work. I've looked online, and people want to help but the info is limited because they may not have the vehicle and only offer suggestions. This may help solve this. What do you think?? I guess I can can go first. 2001 GMC Jimmy 4.3L Stock: CS-130D 100-105A Stock Pulley 52.3mm Belt: 95" H.O. Alt: AD-244 320A from Custom Alternators in Ca Mod: 98.4mm Pulley (Part# 89026) Belt" same 95" -Frank
bighossf150 Posted July 16, 2015 Report Posted July 16, 2015 2006 f150 4.6 with a singer 350 amp uses a Belt from a 2006 f150 with a 4.2 v6 Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
Masterbasser Posted July 24, 2015 Report Posted July 24, 2015 Let me tell you about high output alternators, FOLLOW THE INSTALLATION DIRECTIONS FOLLOW FOLLOW FOLLOW so many people try to jigger rig a system up but when your dealing with high output alternators and big wattage, do not take any shortcuts, NONE. make sure all connections are tight and proper, no loose ring terminals on bolts, everything needs to be a tight fit!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Kenwood excelon ddx795 3 370 amp CES alternators (audio side only) McLaren dome tweeters Crescendo 6.5 ultra neos NVX JAD800.4 4 PA x4 SPL 18's 4 Digital Designs m5's at .7 ohms each 2 K2 80 ah lithiums 3 group 31 agms Ledglow million color (12 piece) 2007 Yukon xl
