4th order design opinions for 4 15s
Beanz
What do yiu guys think of this one? It looks pretty good. Subs are hdc300 15 inch with the subs going to be inverted
Bumps.. This look good guys
Its hard to say anything about it without knowing a lot more specifics. I know you had another thread about bandpass boxes a while back, but I can't remember what you said and I don't want to have to dig up all that info again.
First off we need to what the sealed and ported volumes of the box are & length of the port/what is it tuned to. I'm sure I could figure some of that out from the picture, but that takes time and effort and if you want help you need to make it easy for people to help you, not hard. Then tell us what amp, what vehicle its going in, and what your goals are for system.
About the only thing I can tell you at this point is those subs probably aren't going to work well in a 4th order bandpass, it doesn't have nearly enough port area, and needs bracing.
Builds:
The ratio is 2.5:1 with about 1.5 cubes for the sealed side
. And the ported tuning is at 41 HZ..
Vehicle is going into a escalade ext with 4300rms amp and goals for this is to be a mean demo machine.. The bracing is still on hold for now so we can figure iut how were going to install the subs
Port length is 4.75 inches
And on the other box it had a wall in the middle you guys kinda told me the wall was useless and I didn't have enough port area
So what tuning should I shoot for.. And I have about 162sq inch of port
Like any other high ratio band pass box, the output is going I be pretty peaky. You are probably looking at having good output from mid 30s to mid 40s with it falling off pretty fast above and below that.
For port area I would use at least twice what you have in the picture, so at least 276 sq in.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 756 Guests (See full list)
