reedal Posted July 23, 2015 Author Report Posted July 23, 2015 Thoughts on the new dimensions? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
reedal Posted August 1, 2015 Author Report Posted August 1, 2015 Ok, here's the final draft. Dimensions via torres: http://i1372.photobucket.com/albums/ag321/reedal931/dimensions%20Capture_zpspeagwqtq.jpg~original enclosure model of port configuration: http://i1372.photobucket.com/albums/ag321/reedal931/Enclosure%20Capture_zpsqhmvnoy6.jpg~original cut sheet: http://i1372.photobucket.com/albums/ag321/reedal931/cut%20sheet_zpsk8fmxqkp.jpg~original Thoughts, critiques are welcome. I'm curious as to opinions what material would be best that i can get from home depot or lowes. Tomorrow I'm going to buy a corded router, and in a few moments I'll be placing an order from parts express for a circle jig. Thanks for the feedback guys. I appreciate it. edit: mobile allows to post images the way its supposed to be done, firefox doesn't. sorry for the links SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Triticum Agricolam Posted August 1, 2015 Report Posted August 1, 2015 Its hard to tell from the picture, but it looks like your port is too wide after its splits into two. If its 6.5" wide before the split it should only be 3.25" wide after the split. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
reedal Posted August 2, 2015 Author Report Posted August 2, 2015 Oh ok. Well that makes sense. I kind of thought that when you said the center port would cause them to be separate chambers but I wasn't sure. I'll adjust for that and change my cut sheet SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
reedal Posted August 2, 2015 Author Report Posted August 2, 2015 So if I were to leave it the way I have it designed, that would make my tuning lower than I intend correct? And bottleneck the port? I'll change it so its 3.25 per side, I just want to understand it better for future knowledge SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Triticum Agricolam Posted August 2, 2015 Report Posted August 2, 2015 So if I were to leave it the way I have it designed, that would make my tuning lower than I intend correct? And bottleneck the port? I'll change it so its 3.25 per side, I just want to understand it better for future knowledge No, if you left it the way it was, it would tune you higher. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
reedal Posted August 2, 2015 Author Report Posted August 2, 2015 Oh ok. More port area in the same volume = higher tuning SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Triticum Agricolam Posted August 2, 2015 Report Posted August 2, 2015 Oh ok. More port area in the same volume = higher tuning You got it. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
reedal Posted August 2, 2015 Author Report Posted August 2, 2015 Oh ok. More port area in the same volume = higher tuningYou got it. Thank you for the assistance. It's very much appreciated. Are you able to elaborate as to what JoeX was getting at when he mentioned the box form factor? Can that ratio affect the tuning and/or air movement/velocity or something? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Triticum Agricolam Posted August 2, 2015 Report Posted August 2, 2015 Thank you for the assistance. It's very much appreciated. Are you able to elaborate as to what JoeX was getting at when he mentioned the box form factor? Can that ratio affect the tuning and/or air movement/velocity or something? I'll leave it to JoeX to elaborate on his questions. Box form factor can affect how a box sounds, but this generally only becomes an issue with more unusually shaped boxes. For example, if you had a box that was really long and narrow you could because to have some transmission line like effect that could throw off the tuning. This is actually done intentionally with some home audio enclosures. They are called "mass-loaded transmission-lines" are kind of a combination of a ported box and T-line. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
