Easy Question for you guys...
I listen to Rap 90% of the time. 10% of the time I listen to country.
I have 2 CT Sound Strato 10 inch woofers which will be wired to 1 ohm and powered by an SAE-1000.
A friend and I are building a box. We can get the dimensions ourselves, however, he is saying we should tune to 35 hz, but I'm still hooked on 33 hz.
Could I please get some elaboration and clarification on proper hz tuning for the subwoofers I have, and the music I listen to?
I hate listening to music where there are lows, and my box won't allow those lows to flow freely. That is my main concern.
Any help would be wonderful!
You will never hear the difference between 33 Hz and 35 Hz tunings. Changes in temperature can shift the tuning of your box a Hz or two in either direction anyway. Also the box calculators used to determine port length aren't exact so you could build the box 100% right and still be off on your tuning a Hz or two.
With that being said, I prefer lower tunings, so if it was me I'd shoot for the 33 Hz tune, if not lower.
Builds:
if you want listen to lower freq music(decaf, rap), then id tune pretty low. the lower you tune, the lower ur woofer will play(with out damaging from over excurion). id reccommend tuning around 30 -35. set ur low pas filter around 24-26.
2014 Ford Focus SE Sedan
Factory Sony 10 Speaker Sound System
1994 Ford Bronco
Dual head unit (i kno)
Sony door speakers
Kenwood Rear Speakers
Custom Center console in the works. will house an NVX NSW10"
https://m.facebook.com/WinnsCustomCarAudio/
The difference between the two is minuscule. As long as your box is not pesky you will be fine. You also have to take in account the the resonance fq of your car will effect the tuning a bit as well.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
I believe you mean subsonic at 24-26 which may or may not be the proper set point most likely not.
oops.. yup.. ur right.. i say the 24-26 based on what hes asking.. he likes lowes, this will allow the woofer to play down to these notes and not over extend the coil based on unloading..
1994 Ford Bronco
Sony door speakers
  • Who's Online   0 Members, 0 Anonymous, 3343 Guests (See full list)
