ptcary Posted April 11, 2008 Report Posted April 11, 2008 I spend alot of time in my garage detailing my PT on the weekends, and have a stock electrical system, and only 995 watts rms total running. I plan to upgrade battery and do the 'big three' wiring next month. I want to be able to listen to the stereo/dvd for 3-4 hours at a time without having to start the car. Question is, how do you power a stereo system off of a regular garage power outlet, and without the engine running? Is there an inverter or battery charger that I can connect to my positive and negative terminals that can do this while the car battery os still connected as well? And one step further, can I install them in the car and just run an extension cord to it? PTCary 2003 SMD PT Cruiser 2011 Honda CBR 250R 2010 Mazda 3i Sport MY BUILD LOG
Aaron813 Posted April 12, 2008 Report Posted April 12, 2008 Yes the Powermaster chargers like this one Steve has one of these in Chickens caddy so when the car is parked it can just be plugged in and he said it will just float at like 13 volts maybe he will chime in here and yes on the installing it thats what he did in the Caddy
PaulO2288 Posted April 12, 2008 Report Posted April 12, 2008 Just hook up a battery charger when you doing that. Im getting a charger to help charge my batts anyways to have more steady voltage and to help have my batts fully charged before comps.
ISO Posted April 12, 2008 Report Posted April 12, 2008 http://www.kinetikaudio.com/powersupplies.asp I have been thinking about these, there new for this year. Kinetic had different ones last year. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
