727Designs Posted August 7, 2015 Report Posted August 7, 2015 Other than the amplifier has any other component been used in both installs? -Zach-2010 Toyota TundraFull Hybrid Audio SQ 7" BDS on 37's 2000 Ford Expedition 160+ dB Green Turd -SOLD-
amanley Posted August 8, 2015 Author Report Posted August 8, 2015 None besides the fact both stereos were pioneer.
AA98hoe Posted August 8, 2015 Report Posted August 8, 2015 Check rcas TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
tommyboy Posted August 8, 2015 Report Posted August 8, 2015 Check where you connect your rcas to the amp, try and wiggle them and see if you lose/gain output. I'm having a similar issue with my soundstream rubi 2500. It used to work fine but now I get about half my output. I tried moving the rcas where the male connections on the amp were and found out that they were loose, thus causing the problem. So try that and report back.
Masterbasser Posted August 8, 2015 Report Posted August 8, 2015 could be coil issue on subwoofer, will offset ohm load and make amp put out less power Ive had amp issue before where it was like going half volume when i had 2 amps strapped and 1 of the amp needed repair Kenwood excelon ddx795 3 370 amp CES alternators (audio side only) McLaren dome tweeters Crescendo 6.5 ultra neos NVX JAD800.4 4 PA x4 SPL 18's 4 Digital Designs m5's at .7 ohms each 2 K2 80 ah lithiums 3 group 31 agms Ledglow million color (12 piece) 2007 Yukon xl
Boyakacsha Posted August 8, 2015 Report Posted August 8, 2015 Check the gain knob, DD has had problems with bad gain knobs recently and the problems have manifested themselfs in all kinds of manners.
amanley Posted August 9, 2015 Author Report Posted August 9, 2015 Interesting thanks guys I'll try it all and let you folks know.
