DD M4 issue
amanley
I'm having issues with my M4 and wondering if anyone could help me troubleshoot. Best way I can describe it is it seems like it goes half power sometimes. I can be driving hit a bump(or not) hit the brake, turn left, right ect and it seems like M4 goes half power and all the sudden it goes full power again. It I'm not seeing voltage dip I'm floating around 13.6 most the time. Edit I should mention that this is the second build this amp has been installed in and did the exact same thing, but couldn't find anything wrong with it.
Sounds like loose connections. Double check, make sure all wires are all the way in and tightened down. Same thing at the battery side of the connection. If not, it could just be the amp. Have you emailed DD about it?
Yea I have actually sent the amp in and they found nothing wrong with it this was about a year ago though. Its when it was hardly doing it but now it does it at least 5-6 times a day. I take a look at all the connections again, but they should all be tight.
bad rca is the only thing i can think of if the amp was checked. i know a faulty rca has given this problem to me once before
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
This is a total new install new everything. The RCA came from the same company tho, but I doubt they would use shit RCA. I can check those too. Thanks folks! :)
My first thought was bad rca. I've definitely had this issue before as well.
  • Who's Online   0 Members, 0 Anonymous, 653 Guests (See full list)
