Will this be a good starting point?
toolshed
I am going to build a 4th order for two American bass dx 15s. I am thinking a 24 cube box with 6 cubes sealed and 18 cubes ported. Is this a good starting point? Here are the subs specs
89.8. sensitivity
30.4 free air resonance
.56 vts
89.6 vas
.635 qes
4.764 qms
4 to 5 cuft sealed to 8 to 10 ported i usually make the port removable so you can fine tune it and a crap load of power lol
What vehicle do you have? What are your goals for the box, is it going to be for SPL numbers or do you want it to do well on music? If you want it to be decent at music what frequency will you crossover at? How much power are you going to run?
There are a lot of "right" ways to design a bandpass box, what's going to be best for you depends on your particular situation.
Builds:
It's going into an avalanche. I have 3k watts Going on them. I would like to have it sound decent with music but can probably tame it at low settings. I would like to be able to pull some hair tricks if possible.ha-ha.
Hair tricks probably aren't going to happen, but you should be able to get some pretty decent performance none the less.
My suggestion for box specs would be to make the rear chamber (sealed side) 5.4 cubes, this will give the subs a sealed resonance of 45 Hz, which is around where you will want to tune the front chamber and a QTC of .82, which isn't too far from the most desireable .7. For the front chamber it depends on how peaky you want the box to sound. I hate peaky bass and want a smooth response, so if I were building it for myself I'd make the front chamber 4 cubes tuned to 45 Hz. As you make the front chamber bigger from there it will get louder, but only around a small frequency range. If you make the front 12 cubes it would be about 4.5 db louder but much more peaky. Neither size is right or wrong, its up to you to decide what you want. I give you graphs showing you the difference is output between different front chamber sizes if you like.
No matter what you do I'd take soffhands suggestion and make the port removeable so you can change the tuning after it is built if you desire.
Builds:
You should get good output down to 30 hz or even a little below.
Builds:
How would you face the subs.... I'm going 19in tall and 49.5 wide with the box as the depth with determine the air space. I Was thinking about facing subs forward at the port with a doubled divider in the middle so they are in separate boxes So each sub would have its own port facing into the cab.... Or would it be best to face subs to the middle of the box and port each sub forward into the cab?
  • Who's Online   0 Members, 0 Anonymous, 3349 Guests (See full list)
