Will this be a good starting point?
toolshed
Which direction you face them probably isn't going to make a huge difference. If you drew a sketch of what you have in mind you would probably get a better answer. I would just make sure the motors are in the ported side for better cooling.
Builds:
Your art makes it pretty clear! Good job.
There isn't going to be a huge difference between the two, if I had to pick though I'd go with B since you are less likely to get out of band noise if you can't see the subs through the port. That's really splitting hairs though.
Builds:
If I were to divide chambers I would rather divide the sealed chamber, not sure if you have an specific reason to divide the ported chamber.
1st box built. I ended up with 2.8 cubes on the sealed side and 6.1 in the ported side per 15. The sub is mounted inverted in the ported side. It's pretty loud but didn't really play it loud cuz the glue isn't dry..
  • Who's Online   0 Members, 0 Anonymous, 3349 Guests (See full list)
