Box design for Kicker L7 15
ZDudas
I bought a kicker l7 15 dvc 4 ohm that I am going to run on a MB Quart 1500.1 at 2 ohm final load. I want the box tuned to 32hz and I want the port firing to the driver side and sub facing up. MAX dimensions are 33 in width, 24 in depth, 18 in height. Also which wood would be better for this enclosure, (3/4 MDF or 3/4 Birch?) Thanks! I hope to start building the box this week.
Quality 3/4" plywood (with 7 plys or more), is better than MDF is pretty much every single way except cost.
Builds:
Here is your request, should work in an ext cab truck, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3 5/8", figure is just an assembly guide, port brace is 3/4" MDF, cross-braces are 1 1/4" wooden dowel rods.
Thanks for the design and cut sheet list. That is exactly what I wanted Joe X. How much clearance do I need to have in front of the port?
3 5/8"
The L@zy Hoe
2005 Chevy Tahoe
2,500 Watts of Highs/Mids
4 10 midrange
4 6.5 midwoofers
4 Tweeters
6 Supertweeters
2 Lithium 80AH Batteries
24K Watts
4 Custom 18s
Quad alt setup Rebuilt 250amp and 3 370s
Interior work by Lone Star Auto Works
The Build Log
Like Loud Bass? Click Here!
On 12/5/2014 at 8:06 PM, juan777 said:
See yall there, I'll be the drunk Mexican with aviators on.
On 12/6/2014 at 10:32 PM, boom50cal said:
I did see Juan LMFAO! He REALLY WAS the drunk mexican with Aviators on!
Well I have the design now I'm off to lowes to get the MDF. Building will start today. Any ideas on how I should measure and cut out the square hole for the speaker? And are the 45s in the corners of the box necessary?
The cutout is a square 13 3/4" x 13 3/4" how to cut it will depend on what tools you have available.
  • Who's Online   0 Members, 0 Anonymous, 2418 Guests (See full list)
