Depends on box, how you listen to your music. Some people can make 2 SA woofers last on 2k or better and some people can blow them on 1k. It is all up to the user really, speakers are only told what to do.
Nav-TV Zen V Audio Interface
AudioControl DM-608
(2) Stevens Audio Neo-Comp Full-Size Horns
(4) Faital Pro 6PR160 6.5"
AudioControl LC-6.1200
(1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz
Ampere Audio AA3800.1
Odyssey ODP-AGM48 Battery (Starting)
Odyssey ODX-AGM31 Battery (Trunk)
Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
I would be running them on 1k rms each (probably less if the amp doesn't put out exactly 1k to each sub at 1ohm) but the box I will be using is one from sundownaudio.Com (recommended box for 2 15s) I listen to a lot of rap, edm, country, djsnt, decaf, got160s, and music like that.
How good is your current electrical? Just curious because you may not see a true 2000 watts from that amp. From what I understand is stock electrical can usually supply enough for 2000 watts but it is also my understanding that those amps are very power hungry.
You should be okay though... I have my SA15's paired with a SCV-2000D at half an ohm.
  • 1 month later...
  • Who's Online   1 Member, 0 Anonymous, 331 Guests (See full list)
