2013 Super Duty Build (Triticum, Joe X)
strocket
I could fire it out the side, I just thought that porting it towards the top would provide better sound quality since it was unobstructed. I do have the side of the cab pretty close... what would you say is a minimum distance the port should be from the cab?
For port clearance you only need the minimum dimension of your port. So if your port is 2" x 6", for example, you would need 2" of clearance.
If you can upload or send me your Sketchup file I have an idea that might work for you.
Builds:
Should I send it to the email you have on your facebook? I did another rough sketch. Correct me if I'm wrong, but you calculate port length off of net volume after you subtract driver displacement right? And then once I have my port dimensions I calculate port displacement and subtract that from my net to make sure the driver has enough space. I've been chasing my tail for the last 30min trying to figure this out. This is the biggest brain fart I've ever had.
Sure, you can email it to me. Port length is calculated off of net volume, which is what's left after you subtract out driver displacement and port displacement.
Builds:
Ok..... Here is what I came up with. My final net volume was .98 cu ft. I had to lower the frequency to 34Hz to make everything work out. Here is a picture of the model.
Erics%20Box%20Final%20Model_zpshx8eqnep.
I know you had said that 1.2 cubes would give me a more peaky response and .8 to .9 for a smoother response but because .98 is now my maximum net how can I get more of that punch back? Rap is going to be the primary genre played... should I tune lower?
With .98 cubes you are going to have a decent amount of rising low end response by the time you factor in cabin gain. I would just go with those specs, IMHO.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 2583 Guests (See full list)
