nocturnalrites101 Posted August 16, 2015 Report Posted August 16, 2015 16 cu ft net , port dimensions of 6.125 height x 41.5 width x 52 depthit should be roughly 25hz. can someone double check this
Triticum Agricolam Posted August 16, 2015 Report Posted August 16, 2015 Yup, should be around 25 Hz or slightly less. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Joe X Posted August 16, 2015 Report Posted August 16, 2015 Right around 25Hz, the port inner end should be some 10" to the rear wall or it may tune lower.
nocturnalrites101 Posted August 16, 2015 Author Report Posted August 16, 2015 Right around 25Hz, the port inner end should be some 10" to the rear wall or it may tune lower. if you're talking about the correction factor. that would only effect it like 1 or 1 and half hz tops given how low it is to tune to go lower is a significant length increases
Joe X Posted August 16, 2015 Report Posted August 16, 2015 No not the end correction, that would relate to the bottom side of the box, just the clearance to the back wall, if you are 6 1/8" from the back wall the effective length would extend like if the port turned.
