Well I guess I needed that alternator from system of the month more than I thought. My stock one decided to take a shit on me today. So out it comes
Follow Seth Sharer Designs on Facebook for more frequent updates!
New build coming soon!
20 6.5s wall on two massive drago 5ks
Alt tested good. Re installed and no problems. Maybe loose charge wire.
Replacement stereo is back to its old antics. Crank the bass too high and it all shuts off and resets. Any help here? Thinking not enough juice(alt) but ive got 2 big agms. Anyone think its a ground issue? I know theyr solid and tight but im at the point to where im second guessing everything lol
Any advice would be appreciated
Are you cranking the bass setting on the radio itself, or just the volume? It never hurts to add more/redo grounding. Double check the connections on the headunit harness. Typically though what would cause that to protect would be distortion. I typically try to avoid boosting the bass settings and such on the headunit since it can cause distortion/protect mode. If it's the amps going in to protect, check grounds are tight and cleaned to bare metal. Check gain settings on amps, see if they're distorting. try and use the SMD tool map and find someone with a DD-1 or O-scope. Low voltage can also cause all of it to protect so try using a multimeter to check voltage as you turn it up. Big 3 upgrade is helpful if you haven't done that already. Hopefully you get it figured out!
  • 3 weeks later...
Huge announcement to make!
Getting an alternator. New amps. More subs. More mids and highs. 200 foot of 2/0 wire.
Anybody know what that means?
Getting the wall started!
more information brother
nothing is set in stone yet.
but its looking like an all massive setup. hoping to get on team massive.
2 drago 5ks
1or2 4 channels
20 6.5 subwoofers
rear hatch having 2 15 pro mids and 2 super tweets
undecided on inside the car mids/highs
300 amp alt.
tons of wire.
have a big check coming tuesday and it will all start!
everyone following this build im thinking about making a whole new log to make it easier.
went down an aisle at menards i usually dont go down and found these!
they are ground blocks for home electrical panels.
going to make some great speaker distribution blocks!
8$ each and also have smaller/cheaper ones
so heres how itll go.
each pair of subs wired in series for 8 ohm.
then 10 pairs in parallel for .8
the 4 subs in each corner will each have a pair of blocks.
then from those they each go to the center block then to amp.
received_1312170225465334_zpscenjldra.jp
officially a member of team massive! will have a big update coming soon when everything comes in
