Alpine MRV-1000?
Aniallation
I was cleaning out a buddy's garage, found this amp and he said I can keep it. Seemed pretty old and I didn't think much of it but now I've looked it up and it seems that this was a pretty damn reputable amp back in the day? Does anyone have some testimonies or specs on this thing? From what I've heard it can hit 1000 watts real-world on 14.4 O.o
It is a real nice old school amp, but it doesn't make 1000 watts rms....On the low end around 400 to 600 high end.
Those were some nice amps back then and are worth using for mids and highs or powering a low powered sub.
Copied and pasted from a thread on focusfanatics.com
Original specs:
Power Output: RMS Continuous Power (at 12.0V, 20 Hz to 20 kHz)
Per Channel into 4 ohms - 100W - 0.08% THD
Per Channel into 2 ohms - 200W - 0.3% THD
Bridged into 4 ohms - 400W - 0.3% THD
Dynamic Power (at 14.4V, 20 Hz to 20 kHz)
Per Channel into 4 ohms - 150W - 0.08% THD
Per Channel into 2 ohms - 300W - 0.3% THD
Bridged into 4 ohms - 600W - 0.3% THD
Frequency Response - 8 Hz to 60 kHz - (+0, -1 dB)
Signal-to-Noise Ratio - 105 dBA - (referenced to rated power)
Slew factor - Greater than 5
Input Sensitivity (for rated power ouput) - 200mV to 4.0V (1.0V a center detent)
Input Impedance - 10k ohms
Speaker Impedance - 4 or 2 ohms (Stereo), 4 ohms (Bridged)
Active Dividing Network Frequency and Slope - 50 to 200 Hz, 12 dB per octave
Power Requirement - 11 - 16VDC Negative Ground
Dimensions (W x H x D) - 240mm x 53mm x 330mm (9-7/16" x 2-16" x 13")
Weight - 4.2 kg (9lbs. 4 oz)
THIS IS WHAT A COUPLE OTHER MRV-1000's WERE ACTUALLY TESTED AT.
Actual Tested RMS Continuous Power (at 12.0V, 20 Hz to 20 kHz)
4 ohms stereo - 152.5W x2 - 0.08% THD
2 ohms stereo - 305W x2 - 0.3% THD
4 ohms bridged - 610W x1 - 0.3% THD
Actual Tested RMS Continuous Power (at 14.4V, 20 Hz to 20 kHz)
4 ohms stereo - 228.75W x2 - 0.08% THD
2 ohms stereo - 457.5W x2 - 0.3% THD
4 ohms bridged - 915W x1 - 0.3% THD
4 ohms stereo - 167W x2 - 0.08% THD
2 ohms stereo - 334W x2 - 0.3% THD
4 ohms bridged - 668W x1 - 0.3% THD
4 ohms stereo - 250.5W x2 - 0.08% THD
2 ohms stereo - 501W x2 - 0.3% THD
4 ohms bridged - 1002W x1 - 0.3% THD
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
The v12 line from Alpine was a solid product line back in the day. as stated they were geared more toward highs and mids, due to their clean power.
Pioneer avn p4004 dvd for now
Jl e4300 replaced
Polk audio 4000.4 high & mids for now
Titanium 2000.1 subs amp for now
Crescendo BC2000D on the way 9/11 home at last
Infinity kappa 52.71
Infinity 3032cf
2 Memphis c3 15 d4
The Alpine MRV-F300 I purchased back in '95 is still going strong to this day in the '95 Tahoe I had.
2011 Chevy Silverado LT 5.3L 4x4 Ext.-cab
"Enjoy yourself. It's later than you think."
  • Who's Online   0 Members, 0 Anonymous, 641 Guests (See full list)
