port size and shape help
Ok so im set now on getting a dayton ultimax 15 for my sub stage in a 4cubic foot box tuned at 25hz... i want dual ports so that the box is symmetrical, so areos are the best option. Im trying to figure out how much port area i need for this sub.
Problem is the tuning is so low that the port has to be long. Going a large port area makes it a really long port and making it smaller may give me port noise or not enough port area.
Any help on this would be nice
The sub im getting http://www.parts-express.com/dayton-audio-um15-22-15-ultimax-dvc-subwoofer-2-ohms-per-coil--295-514
The box will be made out of solid red oak wood made for counter tops. 1.5" thick all around. I plan to use 1" round over on top and side edges and then do a nice dark cherry stain on it.
Two 4" round ports for the single 15" 24" in length each, likely they will need to turn somewhere inside the box.
yea i was thinking of 4" rounds, one on each side... i just didnt know if that would be enough port area for a 15, glad to know i can assume correctly. ill post some 3d renderings once im done... i wont actually be building this for about a month cause the wood im using is 100 per 24"x 60" piece so i need 5 boards plus all the stain and plexi glass.
What kind of wood are you going to use?
the wood im using is a 1.5" x 24" x 60" SOLID red oak counter top piece... i plan to 1" radius round the top and side edges and sand very smooth, then stain with a dark cherry color. and ill have an .75" x 8" x 24" acrylic window in the front. a 4" port on each side of the window and the sub in the center facing up.... symmetrical, beauty and going to be strong and heavy... but i really want something unique and nice (not a fan of fiberglass)...
edit: basily the whole box will be that... no cheap veneer stuff. i want to go down to 2000 grit on this, stain and polish
ill stop by the store later and get a real picture of the actual wood id be using.
Butcher-block-giveaway-CeCe-Caldwells-ch
  • Who's Online   0 Members, 0 Anonymous, 628 Guests (See full list)
