Port area ?
toolshed
The ported side of my 4th order is 6.1
I used the slot port calculator on 12 volt .com and it says to be at 45 hz dementions were 8.5 long 4 wide and 17.25 in height. Is that right? Do you use those calculators?
I use anywhere from 12-16 SQIN of port per cube in 4th applications.
If possible, have it adjustable so you can find the best size/depth for your application.
TEAM SOUTH Bassahaulic Productions
The ONLY Bright Atlantic Blue DiamondBoxx L
Drew Jones
4 SSA ZCON 15"s
2 Sundown SCV-6000's
6 AGM G31's
161.6 @ 40Hz Outlaw
159.8 @ 36Hz Legal
┌∩┐(◣_◢)┌∩┐
Based on the numbers you gave that should tune you to about 45 Hz.
Builds:
After its all sealed and dried up, one sub is as loud as 2 were in a sealed box. The 40-45 range is awesome. So should I expect the other sub to be twice as loud when I add it? I'm getting pretty excited here..
When you add the second sub, are you going to be adding more power or wiring to a lower impedance?
Builds:
  • Who's Online   0 Members, 0 Anonymous, 3074 Guests (See full list)
