sTp Posted August 23, 2015 Report Posted August 23, 2015 Hi guys i recently purchased a RF T2D415 sub and a T1000-1bdCP amp to power the sub and i am struggling with the box dimensions for the sub. The dimensions of my boot H = 37cm L = 80cm D = 44cm. Also i would like a slotted port design Don't know if this helps but i mainly listen to drum and bass, dubstep and house as i don't know what the best frequency to tune the box for this type of music. Thanks sTp.
Triticum Agricolam Posted August 23, 2015 Report Posted August 23, 2015 You are probably going to want to tune to the low 30s. Your space is going to be pretty tight for fitting a 15". "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
sTp Posted August 23, 2015 Author Report Posted August 23, 2015 So is it possible to design a box for this size boot also if it is the sub will be looking up to the roof Thanks sTp.
sTp Posted August 23, 2015 Author Report Posted August 23, 2015 thanks for the help Joe as this box is slightly smaller than what RF recommend can it damage anything and will it make that much difference because its smaller than there recommended slot port design also how much bracing would you recommend as in the drawing it just has 2 i guess. sorry for asking so many questions never made a box before only ever brought a pre built one. Thanks sTp.
Joe X Posted August 23, 2015 Report Posted August 23, 2015 If you have any extra space it gets done larger but the 0,25 cubic feet difference is very little and port area is just fine, if you don't have more space the above will work fine.
Joe X Posted August 23, 2015 Report Posted August 23, 2015 Bracing thickness is whatever you can find around 1".
sTp Posted August 23, 2015 Author Report Posted August 23, 2015 OK Joe that perfect just two final question when wiring the sub into the speaker terminal what gauge should i use i brought a RF 4 gauge kit for the install so do i use the speaker wire that came with it and last question is does it need any other internal bracing apart from the 2 shown in the drawing. Thanks sTp.
