Hey guys, been reading for quite a while, finally decided to join.
Let me start off by saying I own both sets of subs already and don't intend to purchase anything else. No other subs, no other amps (for now) and can't fit a bigger box.
This is for daily, although I will throw it on the meter to see if I can outdo my last setup (Three AB HD12s in the same box and amps).
So I have:
Two ZV3 15", dual 2 ohm
Two ZV4 15", dual 2 ohm
In the car I currently have:
Two Skar 2500.1s
7 cube net box with enough baffle space for two 15s and two 6" PSP precision ports, can tune as low as about 31-32hz before port's become too long.
220 amp HO Alt
Deka Group 34
Two Deka Group 31
Skyhigh 2/0 gauge pos and neg run
So each sub will see approx 3.5 cubes net, with a single 6" PSP flared port, on a 2500 at 1 ohm (will try 0.25 ohms as well)
From what I've been reading, that's plenty of space for a ZV3, and the power isn't too bad either. The ZV4 I would imagine likes a bigger box (over 4 cubes), and could take plenty more power in a 3.5 cube box then a 2500 at 1 ohm.
But the ZV4 is a newer, higher excursion, higher motor force driver. I'd imagine better low end extension even though the box is smaller then spec. I'm thinking I could tune them higher without losing much low end either compared to the ZV3s.
Regardless, your opinions folks are highly appreciated on the matter.
Edited by ancorp
If I were you i would try both the zv4s and zv3s and see what sounds better since you already have them both. I would imagine the zv3s being louder though because of the space your working with and the power.
Zv3 wpuld work way better in that.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
  • Who's Online   0 Members, 0 Anonymous, 1559 Guests (See full list)
