Hey guys, so i was on my way into work this morning and subs/amp (2 Rf t1d412s and rf t1500 on stock components ect.) stopped working. Looked under the hood and looks like fuse on RF wiring that goes to battery is blow . I heard this is pretty common? any idea why? I have not done big 3 or upgraded alt or bat. Thanks!
Current Setup:
Mechman 370a Alt 4 pin
DC Triple Alt Bracket
XS3400 Battery
4 Ampere 6.5 components 4 tweets
Ampere 150.4 way
Norcal SS Custom 3/5 Lowering Kit with 3inch Lower Control Arms
DG Roll Pan
LED License Plate Lights
How big of a fuse was it and what is ur current draw. Check wire for exposed wire touching metal.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
It says 100A. Its the one that goes into the clear plastic RF amp wiring kit that goes to Red battery terminal. The shop went with 4AWG should they have went with 1/0 AWG instead?
Current Setup:
XS3400 Battery
Ampere 150.4 way
DG Roll Pan
Could the RVC regulated voltage control thing that flicuates volts to save on gas ect have caused the fuse to blow? Just a thought
Current Setup:
XS3400 Battery
Ampere 150.4 way
DG Roll Pan
I would tend to think no.. Bcs all that does is adjust the voltage.. Drops it down to 12.8 iirc
Amperage blows fuses not voltage
Except as voltage decreases, amperage increases (assuming the supply of current has not been maxed out).
Ok replaced the fuse and will see if blows again, maybe just. Bad fuse
Current Setup:
XS3400 Battery
Ampere 150.4 way
DG Roll Pan
