200 amp fuse is recommended by Rockford.
When I had that same amp I ran 0 gauge and then ran a splitter at the amps.
So they replaced the 100a fuse with a 200 and added a regulator and it blew again today. I also noticed that on a few songs i played the bass seemed to not sync correcty with the music and sometimes on the same song it seemed to hit hard then other times not as hard. Ground?
Current Setup:
Mechman 370a Alt 4 pin
DC Triple Alt Bracket
XS3400 Battery
4 Ampere 6.5 components 4 tweets
Ampere 150.4 way
Norcal SS Custom 3/5 Lowering Kit with 3inch Lower Control Arms
DG Roll Pan
LED License Plate Lights
check your ground to make sure it is not loose. where our you grounded too. pictures help alot.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Yea i am taking it back to them today.
Current Setup:
XS3400 Battery
Ampere 150.4 way
DG Roll Pan
Update:
They traced all of the wiring and could not find anything wrong.
They ran a voltage meter and saw that at some points while playing the subs/amp it would drop below 10 and cause the fuse to blow.
They talked to their Rockford rep and be recommend upgrading my alternator.
Does this seem right? Maybe the alternator is failing? I do notice that the headlights dim in and out when I'm playing it.
I am thinking about going with the Mechman 370 and an excess 3400 battery.
Current Setup:
XS3400 Battery
Ampere 150.4 way
DG Roll Pan
If your voltage is getting that low then yes you need an alternator. Either that or multiple batts but an alt is by far the better choice imo. I doubt your current alt went bad, you are just drawing more current to your amplifier than your stock electrical system can provide, overloading the alt/battery and causing your voltage to drop. You never want your voltage below 11v, 12v is even safer tho.
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
