3sixty.2 was working until I heard a pop
99GPGTX
Was playing fine for 2 days. Went to connect to the 3sixty via ethernet last night. Couldnt get it to work. Unhooked the ethernet from computer and went to turn car on...out of accessory mode. Heard a pop, the system went silent. However come to find out this morning if I crank it all the way up I hear music very faintly. Its faint/scratchy. Any ideas on this guys? Really feelING up shts creek. Just installed all my equipment this weekend. Feeling pretty lost and frustrated thx
Currently:
2015 Evo X WW
Forgestar F14 18s --Rally Armour Mudflaps
ETS 3.5" FMIC, CAI, Open Dump DownPipe, Test Pipe, Ultimate Racing Catback, BLEVINS TUNE, Fortune Auto 500 Coilovers
Build:
Crescendo Mezzos x2
Crescendo 800.4, 1500.1
Loaded Fi Q12
Second Skin Pro
XS D5100
RF 360.2
Sky High Audio Wiring
Need: ALTERNATOR!
PREVIOUS
1999 Grand Prix GTX
3.8L S/C-few modsWheels: Ruff Racing 280 19x8.5 Sub: Fully Loaded
12" Fi BTL Amps: Autotek MM3000.1d Sundown SAX-100.4HU/Tweets/mids:
Alpine D310 + H701, TBI HDSS tweets, Mpyr audio 65m x4extra sheit:
knukonceptz 0, 4, rcas, speaker wire EA 200amp alt HC 2400
TEAM DEADLY HERTZ!!
Financial Consultant- Charles Schwab
i am currently having a similar problem with my mids amp like 1 week ago where the sound was faint and scratchy.....but anyways back to you. are you sure its the 3sixty, try connecting your system without it to make sure. and if it is the 3sixty you might have to send it back
4 Fi Q 12s In A Prius on 4 Crescendo BC2000D?! :WTFBubble: That's Absurd (!!!UNDER CONSTRUCTION!!!) go follow http://www.stevemeadedesigns.com/board/topic/190658-the-first-prius-with-4-12s/
c42977d4-a28f-47b5-a02f-49dbb8697b2d_zps
It has an ethernet port so i was just assuming...
UPDATE.
I plugged directly into AUX to the 360. works fine. but when i try to switch back to CD or bluetooth music it goes back to scratch faint music.
Im still not having luck connecting to the unit via bluetooth :(
Currently:
2015 Evo X WW
Build:
Crescendo Mezzos x2
Loaded Fi Q12
Second Skin Pro
XS D5100
RF 360.2
Need: ALTERNATOR!
PREVIOUS
1999 Grand Prix GTX
TEAM DEADLY HERTZ!!
I downloaded the .2 version and i get this error.
"Access to registry key 'Hkey_local_machine\software\rockford' is denied
hit okay then...
brings up a window that says
3Sixty Software..choose the COM port dedicated to your 3sixty device...drop down menu has Com1-Com99...i can then click start application, demo mode, or exit.
if i click Start App i says..
"Unhandled exeption has occurred in your app. if you click continue, the app will ignore this error and attempt to continue. If you click quit, the app will close. Access to the registry key...'HKEY_LOCAL_MACHINE\SOFTWARE\ROCKFORD' is denied
Currently:
2015 Evo X WW
Build:
Crescendo Mezzos x2
Loaded Fi Q12
Second Skin Pro
XS D5100
RF 360.2
Need: ALTERNATOR!
PREVIOUS
1999 Grand Prix GTX
TEAM DEADLY HERTZ!!
You mean the eithernet port that says com port, where you plug in the knob??
The only way you can connect to it is with bluetooth.
The rj-45 connection on it is a cat-5 cable that has 2 pins reveresed from the standard cat-5 cable.
My guess is you blew something up plugging in a eithernet cable which is a low voltage//current.
hahaha that makes a lot more sense. Thats what i get for listening to my buddy...
However, i dont think the issue is the 360. Since i have Aux hooked up directly to the 360 and it works fine through my phone. has to be something with the HU or a ground?
Currently:
2015 Evo X WW
Build:
Crescendo Mezzos x2
Loaded Fi Q12
Second Skin Pro
XS D5100
RF 360.2
Need: ALTERNATOR!
PREVIOUS
1999 Grand Prix GTX
TEAM DEADLY HERTZ!!
  • Who's Online   0 Members, 0 Anonymous, 1822 Guests (See full list)
