Budget AMP
dev1995
Hey guys My name is Devan. I'm doing a budget system build in a 1990 Ford Bronco 2 I'm going to be running a single HDS215 in a custom ported box. I'm looking for an amp that pushes 700watts@1ohm and I came across the WCC1500 which is rated at 750watts RMS@1ohm an its only $85 on sonicelectronix, what do you guys think? As I said this is a budget build and the box and sub already chewed up more than half I can't spend more than 150 on an amp but if I can get one cheaper that's great
i have something for you but it would require you to spend a few more dollars but it would worth it
Rockford Fosgate PBR500X1 its $179.99 dollars
206 Watts x 1 @ 4-Ohm
365 Watts x 1 @ 2-Ohm
580 Watts x 1 @ 1-Ohm
http://www.sonicelectronix.com/item_43423_Rockford-Fosgate-Punch-PBR500X1.html
and theres the Audiopipe APCL 15001D for $169
  • Sonic Electronix Certified Power Rating*:
    • 4 ohms: 526 watts x 1 chan.
    • 2 ohms: 884 watts x 1 chan.
    • 1 ohm: 1325 watts x 1 chan
http://www.sonicelectronix.com/item_81646_Audiopipe-APCL-15001D.html
Look into PPI black ice. Running two of them pretty hard and theyre doing fine so far. BA2600.1 @1 ohm pushing 2 hds312's with no problems.
2000 Ford Ranger Sport Ext
Digital Designs DD915J
4.91 net birch box, inch port @ 33hz
FSD FZ2600
FSD FZ100.4
Pioneer DEH80PRS
PRV Audio 6MB200-4 6-1/2" Midbass Woofers
Tymphany BC25SC08-04 1" Silk Dome Neodymium Tweeters with Waveguide
Never heard of FSD Audio. I just looked at their so called 3800 wrms amp and it looks like a 2k amp at most. I wouldn't buy it.
LOL!!! Expert!
2010 Focus coupe- 8 12" wall. 157.5@46hz
2016 Focus ST - SQ build.
LOL!!! Expert!
do you think the amp is worth a shot?
  • Who's Online   0 Members, 0 Anonymous, 699 Guests (See full list)
