last ????? can you use those alts on a daily driver???????? if so SOLD!!!!
according to the link, no
300/350 AMP OUTPUT: Powermaster’s SPL alternators utilize special custom wound stators and our own rotor design, in conjunction with the XS VOLT’s capabilities, to create the ultimate car audio alternator. Units typically produce 300 amps at 2000 engine RPMs when used with a 12-volt system and 350 amps when used with 16-volt systems. The SPL alternators are specifically designed for trailer only extreme competition vehicles. Because of the radical design, output at idle is usually 0 and because of additional heat created; these units should not be operated at full output for more than a few minutes.
DC.jpgDC POWER
Actually these will work fine for daily unless you spend alot of time just idling and your idle is below 8 or 900 rpm. These are a little different than the ones shown on the website.
Michael Hughes = 6X SPL World Champion - Loudest on the planet in db Drag, USACi, and IASCA.
$750 for the pair or $450 each.
price includes shipping, insurance, and paypal fees.
for some reason i knew yours werent the normal ones <_<
DC.jpgDC POWER
This topic is now closed to further replies.
