2x swr12d4 box tuning/help
Nismomaniak
I can get 60sqin of port if I make the box 18" deep and use my 6" port at 12" long. Ill have enough room between the port and box as well. Or is there something else im missing other than just port area that Im neglecting? I guess that limits my idea of being able to tune lower too, because I wont have the depth to add more port.
Now im tempted to slot port it, id need an 8" port to make the tuning adjustable like I want it to be. I guess its just not in the cards! Maybe I can use the 6" on my girlfriends box and play with that instead. No pun intended.
I think you might be a little confused on what port area is. A single 6" port has about 30 sq in of port area, regardless of how long it is. Like Joe X said, a single 6" port probably isn't going to be enough. Without enough port area your port velocity will be too high and you will lose output and might have some port noise.
Builds:
Nope, port area is purely a two-dimensional measurement. If you have a port that's 10" wide but 5" tall and 20" long your have 50 sq in of port area. You could make the port longer or shorter and your port area doesn't change. However as you change the length the amount of volume the port takes up will change and so will the tuning frequency.
Builds:
Okay I didn't know that, all I know is what winisd tells me, lol. Its telling me at 4 cubes and a 6" port ill need a 7" port and vent mach will be nearly nothing.
Is there another way I can play with the tuning of a box with this setup? or am I limited to slot porting in your opinions?
How much input power are you simulating in WinISD? I show you getting up into the port velocity danger zone with a single 6" port at about 500 watts.
Builds:
Go to the plot tab and enter the power you will be running, it's not enough to set the sub rated power in the driver window.
  • Who's Online   0 Members, 0 Anonymous, 7626 Guests (See full list)
