Help on a alarm with a cut off switch
Do you want remote start or a theft prevention/lockout system? What they are saying is you don't get both.
Ok np I just thought you can use a relay to send power or ground to bypass the switch but wen the car finish warming up or the alarm is shut of you will still need to hit the switch
THe way the remote start alarms work is that when you activate the remote start the engine runs for a set period of time and the engine will shut off if the brake is pressed without the key in the ignition. No key = no drive.
Get a nice compustar with drone which u can start from your smart phone an track it constantly with gps
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
  • Who's Online   0 Members, 0 Anonymous, 1679 Guests (See full list)
